We live in easter Oregon where the winters are cold enough to cause occasional ice dams and while not required I’m thinking I will install a self adhesive bituminous membrane along the eaves of the roof in our new house. I’m having a difficult time trying to find how far up the roof to run the membrane from the outside wall. Is there some rule of thumb I can use?
2 feet past the edge of the house, at least that is the rule in NY.
24" in MA, too...
What frammer said.
Unless you live up in the Blue's or where there is really considerable snow fall that stays on the roof for long periods of time, then higher.
Are you guys saying buy 36" wide material (like I&WS or Glacier Guard) and cut it down to 24"?
The actual applied width of the material would be dependent on the size of the overhang.
Key is how far up the roof from the plate line .
Gotcha. We don't do that here, it's all 30# felt all day every day.
Don't do it here either, but I understand the concept and the need for it from growing up in Ohio and all the posting on the matter here.
See all the time I spend here has some small benefit!
Edited 8/29/2008 2:23 pm by dovetail97128
I actually had 2 rows installed on my roof! Ice dams, don't you know!
We don't over analyze it. We just run two rows. I believe our local code require 3' inside the building.
The diagram I've seen shows the I&WS to be installed at least 24" measured on a horizontal line beyond the inside wall plane.
http://www.querycat.com/faq/79776683cf3254d8309dcc74aa906a62View Image
Understand that ice dams tend to occur at the point in the roof more or less directly above the building wall, regardless of the amount of overhang. You need to install the membrane beyond that point, and upwards high enough so that backed-up water won't overtop the membrane. The distance is going to depend on the slope of the roof -- you need to go farther on a shallow slope to get the same vertical elevation.
Of course, proper attention to insulation and ventillation can go a long way towards preventing ice dams, though there are situations where they're hard to avoid.
you aren't kidding dan!
I have retro insulated my house every time I do something, then I find another area I missed. I just should have tore out all the plaster and started over.
