Beadboard ceiling
cutter1971 | Posted in Construction Techniques on July 11, 2016 09:52am
I’m getting ready to install beadboard ceiling in my kitchen and living room.  Any advice on which material to use?  I like the thought of using real wood planks (5/16″) but feel they may take longer to install and may warp over time.  Plywood seems to be a good middle ground but more cumbersome to put up and may warp some over time.  MDF seems seems stable and I have to say looks pretty good on the surface, I just don’t like it as a material.
I’d appreciate any guidance on these three material options (and any other tips).
  1. AndyEngel | Jul 11, 2016 01:47pm | #1
    Think about movement
    Plywood would be pretty stable, but you have to figure out how to treat the joints. Wood will move with changes in humidity. If your indoor RH is relatively constant year 'round, not a huge deal. Be sure to leave a gap at both ends of the room that's parallel to the grain to allow for seasonal expension. Cover that with molding. The other choices are fine, but the little defects that show up with wood say to me that it's the real deal. MDF is probably a great choice and it paints exceptionally well, but you have to gap it on all four sides since it doesn't have grain. Same with PVC if you go that route - PVC doesn't change with humidity, but with temperature.
  2. oldhand | Jul 11, 2016 07:15pm | #2
    wood rules....
    If money is no concern it's a no brainer for me. The 5/16" planks are easy to handle and actually look like wood. The end joints will look like wood even with a less than perfect job. Why do these planks look like real wood? Hmmmm.....Anyway,  plywood  will always look like plywood, ditto the  MDF. If the planks warp over time then something is probably done wrong.
    For my thinking plywood is OK for an economy porch ceiling and MDF, umm, well it paints nicely.
    1. DanH | Jul 11, 2016 07:37pm | #3
      Of course, one problem with planks is that you have a lot of seams, and a lot of opportunity for them to open up.
    Mongo | Jul 12, 2016 01:20pm | #4
    Biggest concern for me with sheet goods would be the panel seams, especially the butt seams.
    For a large expanse of ceiling, if you can go with 16' sticks (usually 5/8" thick) you can get a better looking install.
    If you want to use the 5/16" 8' long sticks, the T&G aspect should provide stability.
    You can paint the tongues prior to installation so that if you get significant movement you won't have any unpainted slivers showing.
  4. cutter1971 | Jul 13, 2016 09:40am | #5
    Thanks for the comments.  I'm leaning harder to the real wood.
  5. DiNatale | Jul 14, 2016 06:11pm | #6
    Hi, I’m Adam Brown, Project Manager and Site Supervisor for Peter Di Natale & Associates, Inc. MDF would be my material of choice. Along with the warping issues you mentioned, solid wood expands and contracts depending on environmental conditions. Plywood is rarely flat and, depending on the detail, the laminations may be visible. MDF is stable and is paintable and would be the way I’d go in this situation.
Podcast Episode 691: Replacing Vinyl Siding, Sloping Concrete, and Flat vs. Pitched Roofs
Listeners write in about ground-source heat pumps and weatherstripping and ask questions about engineered siding, concrete that slopes the wrong way, and why houses have pitched roofs.
  • A Postwar Comeback
