Beadboard cutter
Kkissner | Posted in General Discussion on June 19, 2024 11:42am
I am trying to find a bead board cutter for my table saw. Im matching 100+ year old bead board used for the soffit overhang of a roof. The problem Im having is the bead is 3/16 diameter and all Ive found is 1/4” or bigger.
It’s 5 1/4” wide double bead t&g boards 9/16” thick.
thoughts anyone? Thanks
  1. [email protected] | Jun 19, 2024 06:41pm | #1
    Find the corresponding router bit or have your local lumber supplier make you some.
  2. 1095mike | Jun 20, 2024 08:38pm | #2
    check out Corob molding cutters. You can customize their high speed steel knives to get the profile you need. corobcutters.com
