beam lifter/jack
IdahoDon | Posted in Tools for Home Building on November 4, 2006 05:09am
I really like the idea of a beam jack for lifting from floor to ceiling height.  Any favorites?  Cost?  Limitations?
Beer was created so carpenters wouldn’t rule the world.
  1. davidmeiland | Nov 04, 2006 06:09am | #1
    How about something like this?
    http://www.toolfetch.com/Brand/Genie_Lifts/Material_Lifts_Handling/gl-8w.htm?per=25
    1. Renoun | Nov 04, 2006 10:05am | #2
      I think that that Genie is the lift we rented last winter to retrofit a 19' steel I beam flush in a ceiling. Be very careful if you want to use them for flush beams, you may have to set the beam on cribbing above the forks because the lift mechanism may not fit into the joist bays.
  2. Stilletto | Nov 04, 2006 01:25pm | #3
    Piffin and I spoke about one recently in a different thread,  I borrow it from a local iron working shop.  The manufacturers is Vermette.  I probably spelled that wrong.
    The one I borrow is great,  lifts alot of weight quickly.  But it weighs a ton.
    1. Piffin | Nov 04, 2006 02:38pm | #4
      My eaars were tinglinghttp://www.industrialladder.com/products/Vermette_Lifts.htm
      1. Stilletto | Nov 04, 2006 02:53pm | #5
        I was hoping you would read this thread,  you or someone else had posted a link in that other thread.
        1. IdahoDon | Nov 08, 2006 05:57am | #6
          I was sort of hoping for a little less high tech, less $.  Thanks for the links though.
          Most of the beams I'm thinking of are only two-to-three hundred pounds on each end--too heavy for two guys, but relatively light.
          For now we'll continue to use comalongs/pulleys and some carefully supported verticle 4x4 posts.
          1. Tomrocks21212 | Nov 08, 2006 10:26am | #7
            Some stone masons on my site were using an electric winch from Harbor Freight, I think it cost less than $100 and had a 600# capacity. About a 30 ft cable, and was a lot faster than my Maasdam comealongs.
Big Doors Have Big Challenges
Engineered materials and vacuum-press laminations prevent warping and keep a tall, flush-panel door from being excessively heavy.
