Beam Q
PaulBinCT | Posted in Construction Techniques on July 5, 2006 08:23am
OK… I’m afeered that this will betray my lack of “seasoned” status once again but here goes.  I’m going to be taking out a bearing wall with a span of roughly 11′. It’s supports the second floor and attic. House depth is 24′.  Joists are 2×8. I’d like to have a flush ceiling.  From what I’ve seen in various tables it looks like I’m not going to do it with anything but steel.  Correcto?
TIA,
PaulB
    BossHog | Jul 05, 2006 09:03pm | #1
    If 2X8s are 7 1/4", and you put a plate on top of a steel beam, that only leaves you 5 3/4" for a steel beam. I don't know anyone around here who even carries something that short, or if the design would fly.
    Unless you're willing to jump through some hoops to have a flush ceiling, I'd say LVLs would look pretty good.
    Remember the first rule of gun fighting - Have a gun. [Jeff Cooper]
  2. wrudiger | Jul 05, 2006 10:26pm | #2
    Like BossHog said - LVL & joist hangers.  Make sure you put extra support under the 2 ends for the point loads (our engineer spec'd 2'x2'x2' concrete pads).
    EDIT:  Oops, never mind...  Just reread and realized there's that 2nd floor to contend with (ours was just attic).  Good luck!
    Edited 7/5/2006 3:28 pm by wrudiger
  3. Framer | Jul 05, 2006 11:31pm | #3
    They make I-beams 5-1/2". I did a job 2 years ago with one for the same reason your talking about. You can also have engineered a 7-1/4" flitch plate sandwiched in between two 2x's or LVL's. Here's a company I've used before called "Better Header". They have some good stuff available.
    http://betterheader.com/default.asp
    Joe Carola
    Edited 7/5/2006 4:32 pm ET by Framer
    Edited 7/5/2006 5:20 pm ET by Framer
      PaulBinCT | Jul 05, 2006 11:46pm | #4
      Ahhhhhhhhhhhhhhhh I think that's JUST what I'm looking for Joe, thank you!  I can't seem to get their table to work but I shot them an email...
      Thanks,
      PaulB
      1. Framer | Jul 06, 2006 12:25am | #5
        I just used one a couple weeks ago that was 17' 4" and made up of (3)2x10's with (2)3/4" flitch plates in between.Here's a couple shots and you can see how nice and flush the bolts are just in case you had to use a dropped beam you, don't have to pack out.Joe Carola
          PaulBinCT | Jul 06, 2006 12:29am | #6
          You're making my mouth water Joe, it's exactly what I'm trying to do. I'll let you know what they say...
          PaulB
        2. si | Jul 08, 2006 05:50pm | #7
          Interesting product.
          What is the pricing like?
