Below-floor ventilation in stucco wall
| Posted in General Discussion on January 4, 2000 11:56am
My house (about 10 years old) was built with very few vents for the under-floor area. I would like to add some, and have plenty of space between the floor and the top of the foundation wall. The question is: How do I cut these into the stucco wall, and once that is
done, how do I ensure no moisture gets in through the vent opening and into the plywood wall that backs up the stucco?
  1. Guest_ | Dec 07, 1999 01:15am | #1
    Why do you feel like you need more vents? Is there a specific reason or are you just speculating that what you have is not enough?
    There is a lot of controversy over attic ventilation/nonventilation, but non vented crawl spaces are becoming widely accepted. A crawl space is little more than a short basement. Presuming you don't have a radon problem, you could block you existing vents insulate the walls and cover the floor with poly.
    If you insist on venting, first consider making a louvered access door.
    You can saw cut holes in the stucco with a masonry or diamond blade and put in screened vents. Careful caulking should take care of any potential leakage problem.
    1. Guest_ | Dec 07, 1999 01:46am | #2
      *> Why do you feel like you need more vents? Is there a specific reason or are you just speculating that what you have is not enough? The ground under the house remains damp even at the end of summer--I'm concerned that this will attract termites, cause mildew, etc.
Outdoor Lighting
  • A Postwar Comeback
  • Natural Simplicity
  • A Grand Rescue on the Coast
