Bending Laminate
| Posted in General Discussion on March 15, 1999 10:06am
Want to bend some laminate on the edge of a countertop so as not to have the square edge that always seems to catch clothes and kids heads.
What radius will the average laminate bend around (talking the 1 1/2″ wide strip that forms the front edge of a countertop)?
What is the technique for applying the laminate to the bend?
Thanks.
  1. Guest_ | Mar 09, 1999 05:32am | #1
    Six inches is a pretty standard radius for countertop corners, and standard laminate will conform to it pretty easily.
    If you want a smaller radius, you can try heating the laminate strip (hair dryers work ok, maybe an iron, but NO open flames like propane torches).
    You can also belt-sand the back of the laminate to make it a bit thinner (at the site of the radius)so it will take a tighter bend.
    If you're going for the tighter radius, try a dry fit before spreading any contact cement (but then, you knew that).
    --Jay
    1. Guest_ | Mar 09, 1999 05:54am | #2
      *Use a heat gun (your wife's hairdryer may even work, maybe an iron) to heat the laminate where you want it to bend. You may want to experiment to see how small a radius you can get. I've done a 3" radius, haven't tried smaller, but it could be possible. After you've prebent the edging, spray, roll or brush on the contact cement. Let dry and do it again ( countertop too). Hope this helps.
      1. Guest_ | Mar 09, 1999 07:22am | #3
        *Agree with all on the heat gun(use care) add edge clamps until the contact gets a good set.
  2. JR_ | Mar 10, 1999 06:44am | #4
    Keep in mind that some laminates are not bendable,
    mainly the metallic colors.
    JR
    1. Frank_N | Mar 15, 1999 10:06am | #5
      *Try using vertical grade laminate for you radius if you have problems with the previous mentioned methods. Vertical grade is a thinner material that you can almost wrap a pencil with if you heat itFrank N.
  3. Rich_B. | Mar 15, 1999 10:06am | #6
    What radius will the average laminate bend around (talking the 1 1/2" wide strip that forms the front edge of a countertop)?
    Thanks.
Podcast Episode 691: Replacing Vinyl Siding, Sloping Concrete, and Flat vs. Pitched Roofs
Listeners write in about ground-source heat pumps and weatherstripping and ask questions about engineered siding, concrete that slopes the wrong way, and why houses have pitched roofs.
  • A Postwar Comeback
