I just noticed that my favorite Architecture book is now available for free.
Here is a link to a digitized version…. Mr Hand on page 9 is kinda funny…but what the Hey this book is free!
Easy-to-make tools simplify the framing, while time-tested flashing techniques make it last a lifetime.
Check out the early "mooney wall" on Page 99
http://books.google.com/books?id=plY1AAAAMAAJ&pg=PA167&dq=William+a+radford+old+house+tin+drawings#PPA99,M1
Not really a Mooney wall. It is really a vent skin wall.
Not unlike the modern vent skin walls for siding but is utilized a bit differently.
Tore down an old ice house here built with that construction.
Dovetail,
that was me comparing it to a mooney wall.
Similar in that the furring strips are reducing thermal bridging.
I noticed that they used sawdust to pack the walls.
Some of the other details in the book showed 2 layers of 2 inch cork.
I am not familiar with vent skin walls.
Can you describe the vent skin wall a little more?
Edited 5/10/2009 5:22 pm by homedesign
Rain Screen/ Vent Skin. Siding is hung on furring strips so that there is air/water passage behind it. Utilizes the same thermal "chimney" concept for heat reduction.
Keeping the siding off the sheathing helps reduce heat gain and also allows a passage for water to drain out.
homedesign,
You are a champ.
Thank you for that link.
I have the "Complete Cyclopedia of Construction"
Same company , 9 or 10 books IIRC
Good reading.
Very cool. I noticed on page 56 they show a metal joist hangar (although it's made of wrought iron instead of galvanized steel.) I didn't realize they were using joist hangars back then.
http://books.google.com/books?id=plY1AAAAMAAJ&pg=PA167&dq=William+a+radford+old+house+tin+drawings#PPA186,M1
Page 186 ....
does anyone know what a fireless cooker is?
What is excelsior?
excelsior is what Marvel Comics' editor-in-chief used in his 1960s-70s salutation when signing out of his monthly 'Marvel Bullpen' comments on the readers page.
Excelsior is a packing or insulation material.
Wood shredded into long fibers is what I think of . http://en.wikipedia.org/wiki/Wood_wool I am guessing that the idea of that box is that a kettle is
pre-heated and set in the insulated chambers to finish cooking or the galvanized liners are to hold hot water.
Edited 5/10/2009 3:50 pm by dovetail97128
Remember you teenage architecture hounds. Practice safe page turning.
Always put a widget on your digit.
Thanks for the link. Like how those risers are rabbeted into the treads.
