Best Composite for Dock Surface
BMan | Posted in General Discussion on May 18, 2007 04:45am
I need a roll-in dock. I would prefer to use composite decking on the aluminum frame, but am thinking the span between supports will be too great for the composites (4′-0″). Standard products use 2x cedar, or aluminum plank. The cedar is a bit bouncy- this is not like standard deck building. The aluminum plank is pricey. It is necessary to keep it light, or I would just use Ipe.
In your vast experience, would a composite deck product work?
  1. mike_maines | May 18, 2007 04:50am | #1
    In my half-vast experience, I think the aluminum is the way to go--it's what I used for my dock.  It's light and strong, and won't rust or splinter.  Composite decking is heavy.  Not as heavy as Ipe, but not far off either.
    1. BMan | May 18, 2007 02:47pm | #2
      Does that aluminum get hot?
      1. mike_maines | May 18, 2007 02:56pm | #3
        Warm, but bearable.  It's mill finish so it reflects much of the radiation and it's a good conductor so it gives the heat back to the air.
        1. BMan | May 18, 2007 03:03pm | #4
          Thanks much!
  2. RobWes | May 18, 2007 11:40pm | #5
    Make the decking into removable panels that are held in place with just a few SS screws. I did it for my wheel in/out dock and was thrilled with the end result. I had 5' X 26' of dock made out of 2 X 8 PT and galv hardware. Made the panels out of 5/4 red cedar. There was no bounce at all when all the legs were lowered and pounded into the lake bed.
    If I was to build another, I'd think about bar joists. Someone not polished on their boat docking skills could hurt that aluminum frame work.
    Ditto on the weight factor
    Edited 5/18/2007 4:41 pm ET by RobWes
