Best Cup Hinge Design?
bmyyou | Posted in General Discussion on September 11, 2009 07:02am
Is it better to use a face frame cup hinge that attaches to the face frame edge with 2 screws or 1? The Salice cup hinges are single piece and have 2 attach points versus the single piece Blum and Amerock hinges that have 1.
Would the hinges with 2 screws will be more likely to splitting the frame’s edge from use over time.
Does everyone mostly use Blum?
    ToolFreakBlue | Sep 11, 2009 07:24am | #1
    The Blum face frame plates I use have two mounting holes.
    Predrill unless poplar.
    I would be leary of one hole mounting.
    TFB (Bill)
    PeterJ | Sep 11, 2009 10:27am | #2
    I've installed gobs of the single screw Salice which, IMHO is a better hinge than a Blum Compact. Only time I've had screw holding concerns is on plywood or thin face frames. On softer woods I might use a longer screw, say 1" instead of 3/4". I do use cutter tip screws which helps prevent splitting.
    OTOH, if I were using conventional Euro hinge and face frame bases, I'd use Blum Clip Top, which is superior to Salice Clip. The advantage to this setup is greater adjustability than compact hinges, the disadvantage is they hang into cabinet a couple of inches.
    Edit: On re-reading I see you're talking about double screw Salice, a little fussier to install, but uses smaller screws, like #6 x 5/8.
    Edited 9/11/2009 3:31 am ET by PeterJ
Eichlers Get an Upgrade
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
