best finish for new redwood deck
djohan | Posted in Construction Techniques on August 26, 2005 11:25am
Just finishing up pulling out a trex deck which the homeowner doesn’t like the look of.  He apparently had a wood deck previously and we will replace the trex with redwood.  Go figure.  Now comes the question of a finish for the redwood.  We used a variety of pentrating wood finishes when we regularly installed wood decks a number of years ago.  I imagine better finishes have come on the market in the past ten years.  The deck is on the central coast of Ca. so snow isn’t a factor, but it will get splashed by sprinklers and go through the normal wet/dry seasons.
Would appreciate knowing about any finish you use and like that has a good track record of at least five years.
Dennis
  1. rez | Sep 01, 2005 10:38pm | #1
    Greetings dj,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again.
    Perhaps it will catch someones attention that can help you with advice.
    Cheers
    as Buddha said to the hotdog vendor .... "make me one with everything"
    DDay | Sep 01, 2005 11:25pm | #2
    The two I have seen mentioned most here are messmers and penofin.  I have not used it on redwood, only Ipe, but it work great.  It is a penetrating oil finish that will protect the wood very well.  You can check out the websites.  I've used penofin but messmers is pretty much the same.
    http://www.messmers.com/
    http://www.penofin.com/
  3. marv | Sep 01, 2005 11:42pm | #3
    If you use stain with some UV protection, plan to re-do every 2 or 3 years.
    If you use a clear to try and keep the "Redwood" look, plan to redo every year.
    I would use a product like Thompsons water seal and sit back and let it grey.
    You get out of life what you put into it......minus taxes.
    Marv
    LEMONJELLO | Sep 02, 2005 07:52am | #4
    penofin, used it on a couple of decks in the north bay,Marin area and works great,4 years and HO retreated as directed, looked at it while visiting some family in the area last month. still nice
    Note> keep the sprinklers off/away from the deck! the bleaching effect and minerals and whatever else is in the water has ruined many a redwood deck and fence in the Northern CA area so I imagine it would do the same in the Central Coast too.I cut the board twice and its still too short ! ! !
    I didn't use a thompsons cause the ones I have seen lift and peel a lot, although could be a poor application as the cause.
    Edited 9/2/2005 12:55 am ET by LEMONJELLO
    1. MRinger | Sep 02, 2005 02:06pm | #5
      Diddo LEMONJELLO I would use Penofin
Outdoor Lighting
  • A Postwar Comeback
  • Natural Simplicity
  • A Grand Rescue on the Coast
