Best floor joist or truss construction to span 26 ft
mike78 | Posted in Construction Techniques on May 2, 2012 11:32am
I am planning a home addition that will be 26′ x 26′, two floors above a walk out basement foundation. 26 ft can be clear spanned with I-Joists or wood floor trusses. I could also use a steel beam in the basement ceiling plus load bearing walls on the first floor to cut the 1st/2nd floor joist spans in half and use SYP 2X12s.
To achieve stiffness and strength equivalent to SYP 2x12s with 13′ span, I expect that wood floor trusses with 26′ span might have to be 18-20 inches deep.
Are there any tradeoffs related to impact sound transmission between floors if load bearing walls are eliminated ? If floor loads are carried only by perimeter walls, I wonder if there are less paths for impact sound compared to a system with additional interior load bearing beams, walls and columns ?
Thanks,
Mike
  1. IdahoDon | May 03, 2012 12:29am | #1
    There's no reason to not have a steel beam instead of a load bearing wall for the upper floor as well.   I'd say that you'll get more noise with the beams built to minimum standards since load bearing walls will dampen a lot of harmonics/vibrations, but if you go beyond minimum construction and include decent floor insulation, and strapping or resilant channels, and flooring with a solid subfloor (perhaps even thin concrete and radiant heat!) you can built either one to be better than "normal" variations of the other.
    xxPaulCPxx | May 03, 2012 12:20pm | #2
    The 26' span can be open using TJI 360 or 560 floor joists on 16" OC... they are 16" deep.
  3. IdahoDon | May 05, 2012 03:25pm | #3
    Also keep in mind that as you go to longer spans you'll want a stiffer floor or it will feel "bouncy".  L/360 stiffness would be horrible over 26'.   At least one of the I joist makers (boise Cascade?) had an online caculator that gives you a number of relative felt stifness - can't say how close it comes to real life but it's an important concept if spongy floors bothers you.
    BossHog | May 10, 2012 06:40pm | #4
    I feel like I've beat this horse to death. But with any floor question like this one I refer people to the thread on floor vibration:
    http://forums.finehomebuilding.com/breaktime/general-discussion/floor-vibration
