Best Glue ???
woodway | Posted in Construction Techniques on February 21, 2007 02:12am
Can’t find prior posts regarding best glue to use so here’s my question
I’m gluing up several trusses for a shed and will be applying gussets with glue and gun nails. What’s the best glue for the job? Gorilla glue was my original first choice but then a tube of construction adhesive came my way and now I’m not so sure.
  1. jrnbj | Feb 21, 2007 03:07am | #1
    Let me be the first to YELL at you for having the nerve to make your own trusses ;-)
    1. woodway | Feb 21, 2007 09:12pm | #8
      Hey, it's only a back yard storage shed.
      1. jrnbj | Feb 22, 2007 02:05am | #10
        Well, you did get a few "how comes?".....I'm surprised you didn't get more, but I guess you said "shed" too quick for a proper flaming...
        mind you a shed could be a pretty big structure ;-)
    zak | Feb 21, 2007 03:29am | #2
    PL premium construction adhesive, but I'm not convinced you should be making your own trusses.
    Why are you doing this?  Stick framing is simple, reliable way to frame something like a shed.  Anyway, I'm sure you'll get an earful from others.
    zak
    "When we build, let us think that we build forever.  Let it not be for present delight nor for present use alone." --John Ruskin
    "so it goes"
    1. ebeveridge | Feb 21, 2007 04:41pm | #7
      I used PL, 1/2 ply gussets and screws. it was a activity in class to show how trusses were made. ;) shed has been up for 5 years and no problems. maybe I should tell those kids that they passes. o well
      1. woodway | Feb 21, 2007 09:23pm | #9
        Thanks guys, PL Premium it is.
  3. Piffin | Feb 21, 2007 03:55am | #3
    Gorilla does not have the shear strength for this application.
    Regular construction adhesive will allow "creep" and not hold tight in this shear setting
    PL Premium will cure hard even in cold and damp. Get some.
    It's just a small shed so ignore the guys worried about you building trussses for it and have fun. If it falls down - learn something from it.
    1. onder | Feb 21, 2007 04:14am | #4
      I was doing some glueup yesterday. Temp in the
      room was around 55 but it has been very dry and
      cold here lately.  I absent mindedly neglected to
      wipe one surface with a damp sponge and I
      noticed a very slow glue set up.
      PL is great stuff but it needs the damp.
    2. pinko | Feb 21, 2007 04:14am | #5
      Ain't nothin built w/ PL premium going to "fall down".
    IMERC | Feb 21, 2007 07:20am | #6
    it's a shed...
    tell the yellers to stuff it...
    Pl Premium.. no subsitutes...
    WOW!!! What a Ride!
Versatile Vise
