best gutter joint sealing method
WillieWonka | Posted in General Discussion on May 26, 2009 09:43am
What is the best way to get a positive leak free joint where you install end caps, mitre corners and drop outlets in seamless gutters.
The method I been taught is fit the pieces together, drill holes, then use lots of silicone, join and pop rivet. I’ve done this and I STILL get leaks at times. I want to make my joints more durable and higher quality if such a method exists.
If at first you don’t succeed, try using a hammer next time…everything needs some extra persuasion from time to time.  -ME
  1. Hackinatit | May 27, 2009 12:26am | #1
    Polyurethane gutter caulk.... takes paint and "no leaky"
    A La Carte Government funding... the real democracy.
    1. mikeroop | May 27, 2009 12:58am | #2
      get the gutter caulk it's way better than silicone!
      1. JHOLE | May 27, 2009 01:01am | #3
        Ditto...Remodeling Contractor just on the other side of the Glass City
        1. seeyou | May 27, 2009 01:07am | #4
          Trittohttp://www.quittintime.com/      View Image
          1. JHOLE | May 27, 2009 05:35am | #5
            Squat.Remodeling Contractor just on the other side of the Glass City
  2. Piffin | May 27, 2009 01:37pm | #6
    silicone hardens and breaks bind with metal under the stress of thermal expansion/contraction. A flexible caulk like geocell is better.
  3. JTC1 | May 27, 2009 03:09pm | #7
    No silicone.
    Like many others, I use a product which is called "Gutter Rubber" - available as a caulk gun sized tubes or a toothpaste sized tube at the local roofing supply house.
    At least on an appearance basis, the same product is available at HD - called "SeamerMate". Caulk gun or small toothpaste sized tubes. Seems to be the same stuff.
    Both are a sparkle-y silver gray in appearance when wet, somewhat self leveling, "toolable" with a wet finger, skin over pretty quickly, are v-e-r-y stretchy when cured and form a very good bond on a clean dry surface. Clean up with mineral spirits.
    I find the toothpaste sized tubes are more convenient to maneuver with the gutter already in place.
    Jim
