Best interior wall slab anchor?
blownonfuel | Posted in Construction Techniques on July 2, 2008 05:33am
Hello. What type of anchor do you use when securing interior wall sole plates to a slab?
Stud with epoxy, expansion type, hardened nails?
I would like to use one the resists pull out the most. From what I have read the epoxy ones seem to do the best.
Thanks as always.
  1. KenHill3 | Jul 02, 2008 05:40pm | #1
    Split drive. Fast and easy. Seems pretty good for pull-out strength.
    http://www.confast.com/products/split-drive-anchor.aspx?gclid=CJ6Q94a3oZQCFRcaagodgB7gtg
    1. blownonfuel | Jul 02, 2008 07:53pm | #3
      Thanks Ken. I think Simpson makes a split drive also.
  2. BillBrennen | Jul 02, 2008 07:06pm | #2
    Most interior partitions, 1/4" Tapcons are all the pull-out resistance you will need. The studs will pull off the plate before the Tapcons will pull out of the slab.
    Shearwalls, then the epoxied studs are the way to go, with the big square washers.
    Bill
    1. blownonfuel | Jul 02, 2008 07:54pm | #4
      Thanks Bill. Have you ever used one of the new Titen HD anchors by Simpson?
      1. BillBrennen | Jul 02, 2008 09:41pm | #5
        Yes, I have used Titens, but only in the big sizes. They are like huge Tapcons. Fast, strong, and reversable.
Two Ways to Test Windows
  • The New Old Colonial
