Best Location With Respect to Shingle for Roof Vent Pipe
Alumino | Posted in General Discussion on December 19, 2012 01:49am
Where is the best location (with respect to the shingle) to cut a hole for a new 4″ roof vent pipe?
I am installing a Radon system that will terminate in a 4″ roof vent pipe in the garage.  I can place the roof penetration pretty much anywhere (Left-Right, Up-Down) I want.  Is there a “sweet spot” location with respect to the Architectural Shingle — i.e. a spot that make the work the easiest or makes the roof the tightest?
Do I want the “hill” on the flashing to sit just at the bottom of the shingle?  Do I want to cut a semi-circle in the shingle to go around the “hill”?  Does it even matter?
Do I want it between two shingles? In the middle of a shingle?  Basically, if a roofer said, “I wish they had put the pipe right THERE!” where would that be?
Roof is typical architectural shingle, 12/12 or 10/12 I think.  I plan to terminate with a black ABS pipe through the appropriate Oatey flashing I can get at the Blue, Orange or Green big box store.
Thanks,
Tim
    BossHog | Dec 19, 2012 08:08pm | #1
    IMHO you're over thinking it., Just cut a hole and put it in.  It will work out fine.
  2. DoRight | Dec 19, 2012 09:00pm | #2
    Anywhere is fine as for shingles.
    If you are in snow country get it close to teh ridge or it can get sheared off.  More of a problem with metal roofs, but I have seen problems with asphalt shingles.
  3. florida | Dec 20, 2012 03:48pm | #3
    As long as it's flashed correctly it will make no difference at all.
