Best material for a router table fence?
JIMMIE | Posted in General Discussion on January 29, 2007 10:43am
I need to make a fence for my router table.  I’ve several magazine articles with plans. Some use 3/4″ ply, some use MDF, and some use Maple?
Your experiences and suggestions would be appreciated. If there are any plywood fans, what’s the best type and where can I get flat material?
Thank You
  1. JMadson | Jan 29, 2007 10:56pm | #1
    I'm using 3/4" mdf. The wood slides nice against it, very flat too.
    “The richest genius, like the most fertile soil, when uncultivated, shoots up into the rankest weeds..” – Hume
    1. JIMMIE | Jan 30, 2007 12:16am | #3
      Thank You.
      Did you stain or varnish the MDF?
      1. Sancho | Jan 30, 2007 12:22am | #4
        i use shrt pieces of 2" aluminum angle stock. then attach 1/2" hardwood to it
        View Image    Official Jeff Buck Memorial Tagline "
      2. JMadson | Jan 30, 2007 01:21am | #6
        Plain MDF has pretty smooth surface as is (as long as it's not a cut surface)
        The UHMW from another poster is also a good choice.“The richest genius, like the most fertile soil, when uncultivated, shoots up into the rankest weeds..” – Hume
  2. CAGIV | Jan 29, 2007 11:32pm | #2
    I use 3/4 MDF, it lays flat and stays smooth.  It has an aluminum backing so strenght isn't an issue, it it was going to be the main structure of the fence I would be worried it would flex
    I've thought about melamine because it's smoother and probably would glide easier, just never had any around when the fence needed replaced
    Team Logo
  3. cynwyd | Jan 30, 2007 12:37am | #5
    I've used all those choices with satisfaction but what I wanted to add was the suggestion of a UHMH sheet to whatever your choice is.
    Then I found this;
    http://item.express.ebay.com/ws/eBayISAPI.dll?ExpressItem&item=200067592279&pid=&wlid=1478354&wlitemid=2244394
    This stuff makes other choices seem, like well, a drag.
  4. bayviewrr | Jan 30, 2007 04:23am | #7
    Fifteen years ago I made my fence out of two pieces of 1x4 scrap oak glued and clamped.  To this day, it is a straight as an arrow and has been used countless times.  Can't compain about that.
    Brian.....Bayview Renovation
  5. IdahoDon | Jan 30, 2007 05:57am | #8
    The "best" would depend quite a lot on how it's used, how often it's used, how it's stored, and a number of other things.
    I'm often milling wood outside and need a decent size router table that is easily transported and durable so my needs are much different from others.  Professional carpentry is speed based, even the highest quality work, so the fence also has to be quick to set up and adjust.
    For years I simply grabbed a 3' board and clamped it to my router table (3'x2' AC birch plywood).  With two quickgrip clamps a straight 2x4 can be adjusted quite easily and micro adjusted with a hammer tap.  Unfortunately, it doesn't have dust collection and takes more time than it should to cut away bit clearance.  Many very good finish carps still use a simple board as a router fence on the jobsite.
    While culling scraps from a scratch build oak staircase a proper fence was made from some very nicely grained and stable oak.  Much of what you'll find, hardwood or not, is simply not going to be stable over the long haul because the grain is not right or there are internal tensions from improper drying or whatnot.  Vertical grain wood is quite stable, and those that stay true while being cut are the best of all.
    After using the oak fence for a year I needed to reduce setup times and gain dust collection so switched to the Bench Dog Pro fence.  As you can see it's a rather simple design, essentially an aluminum angle with misc. knobs and slotted tracks to attach and adjust it.
    If I had a little more time to tinker, the same design could have been replicated for less than the $150, but I'm a big fan of the simple aluminum angle with adjustable wood faces for 99% of all on site finish carpentry uses.
    If you want some great ideas and a design that is top notch check out http://www.patwarner.com/ View Image
    IMERC | Jan 30, 2007 07:03am | #9
    sq or rectangle tube AL and a hardwood face sanded baby smooth and waxed...
    WOW!!! What a Ride!
  7. DougU | Jan 30, 2007 07:31am | #10
    Jimmie
    I use MDF because I make a lot of sacraficial fences and the stuff is cheap.
    I second the PatWarner.com web site, a lot of good info there.
  8. user-158769 | Jan 30, 2007 08:00am | #11
    My router fence pretty much is a copy of the Pat Warner design shown in the previous post...but I made mine from 3/4 inch thick scraps of cabinet grade oak plywood. I glue 2 pieces togetherand I also glued a piece of formica to it. The formica keeps the plywood form bowing, and is great to slide against.
    Davo
  9. TomT226 | Jan 30, 2007 03:09pm | #12
    I just use white 3/4" melamine shelf stock and rip it to width.  The white surface makes it easy to make indexing marks when running a lot of mortises.
    1. stevent1 | Jan 30, 2007 04:54pm | #13
      Jimmie,
      I use a 3/4"melamine base and a 8/4 X 3" rift sawn staight edge.
      Chuck S.live, work, build, ...better with wood
