Best materials for exterior handrails…
| Posted in General Discussion on January 4, 2000 11:28am
I recently completed decorative columns on a wrap-around porch and want to add a railing system. Does anyone have a suggestion as to what products would be best to use for durability, weather resistance and strength? Are any of the new composite materials worth using for a rail system? I had planned on using cypress or douglas fir. For the columns, I used MDO and trimmed them out with cypress. While cost is a factor, it is my own home and I expect to stay in it for a long time so it is not the primary consideration.
  1. Guest_ | Nov 08, 1999 04:19pm | #1
    We are finishing a hoouse with vinyl rails. They are not a bad looking system. Good and strong. This is a new system and isnt as expensive as a lot of the others we have looked at. Cuts way down on labor and eliminates painting. Materila is about double that of treated pine.
    Rick Tuk
    1. Guest_ | Nov 08, 1999 08:32pm | #3
      *brand?
      1. Guest_ | Nov 09, 1999 08:47am | #5
        *Assuming you want a painted look rail...I have seen fiberglass rail systems at Home Cheapo (or someplace) that I believe are a step above the vinyl ones that Rick refers to. Kind of pricey though.
        1. Guest_ | Nov 09, 1999 11:26am | #6
          *Stain grade? Paint grade? Real wood? Fake plastic?
          1. Guest_ | Nov 09, 1999 03:36pm | #7
            *AndrewI ment to ask the distributor yesterday. One word of advise, if using vinyl, make sure of the placement of your posts. You cant make a gooseneck at the top of the stairs.Rick Tuk
          2. Guest_ | Nov 09, 1999 07:53pm | #8
            *"Does anyone have a suggestion as to what products would be best to use for durability, weather resistance and strength?"Sure. Stone.
          3. Guest_ | Nov 08, 1999 04:19pm | #2
            *We are finishing a hoouse with vinyl rails. They are not a bad looking system. Good and strong. This is a new system and isnt as expensive as a lot of the others we have looked at. Cuts way down on labor and eliminates painting. Materila is about double that of treated pine. Rick Tuk
          4. Guest_ | Nov 08, 1999 08:32pm | #4
            *brand?
  2. mccormick | Jan 04, 2000 11:28pm | #9
