Best method for “antique” cutting paving bricks
user-3795461 | Posted in General Discussion on September 4, 2014 10:12am
Hi,
I will be installing a small walkway in a herringbone pattern using old Purington pavers.  They are almost 4 inches thick and 4 inches wide and are about 9 inches long.  To do the herringbone, I will have to cut a lot of triangular pieces.  These bricks are pretty tempered so I am curious as to the best way to cut them.  Any advice is greatly appreciated.
Regards,
Darryl
  1. DanH | Sep 04, 2014 08:13pm | #1
    I think a guillotine might do the job and maintain the desired "rustic" appearance.  Of course, if you don't care for rustic and/or you need precision then a saw is what you want.
    (If I were doing it and only had a few to cut I'd probably have a shot with a toothed stone chisel.  But I'd never attempt to cut bunches that way.)
Townhouse Transformation
A sleek, modern redesign maximizes space and light while preserving the building's historical charm.
