Best nails for plywood subfloor?
| Posted in General Discussion on May 16, 1999 05:32am
Matt, I’ve always felt that ring shanks work best to eliminate nail popping, and a good adhesive between the sheathing and joists should eliminate any concern for squeeks.
  1. Guest_ | May 16, 1999 05:24pm | #5
    In your opinion, what are the best nails to hold 3/4" T&G plywood interior subfloor to the 2x10 joists? I always assumed that ringshank were the best, but reciently I read that smooth were better (in Gene L's book). My primary concern is preventing squeaks, and secondary concern is nail pops.
    OK now, I know someone will chime in and say "screw it!" , but I don't know of any screws that will fit in my framer's Sencos!
    1. Guest_ | May 15, 1999 06:20am | #1
      *Well here is the dreaded chime. Screew it if you want the best fastner. If you must nail, use a good bead of const. adhesive, and use good glue coated nails set to a depth just below flush. I've used clip and full head nails, screew shanks and slicks all without call backs. My nailers drive the slicks to a more consistant depth though.
      1. Guest_ | May 15, 1999 07:25am | #2
        *Here in So. Cal. we use a 10d short also called a 10d plywood nail. It has the gauge of a 10d but is not as long. All the strength in the nails is in shear. A longer nail will "pop" more easily in wet lumber than a shorter one. Use glue to prevent squeeks.
        1. Guest_ | May 15, 1999 09:44am | #3
          *...and hand nail it if you want a nice job. I think hand driven ring shanks are the best (not fastest). - yb
          1. Deemark | May 16, 1999 05:32am | #4
            *Matt, I've always felt that ring shanks work best to eliminate nail popping, and a good adhesive between the sheathing and joists should eliminate any concern for squeeks.
          2. Guest_ | May 16, 1999 05:24pm | #6
            *Thanks all for your thoughts.MG
  • xoxo test post 3
  • xoxo test post 2
  • xoxo test post 1
