Best non-yellowing oil paint?
LouNC | Posted in General Discussion on December 13, 2006 06:04am
I’m working on refinishing kitchen cabinets and want to use the best quality, non-yellowing oil based paint I can buy.  I plan to spray.  I understand all about the importance of surface preparation, priming, etc, and plan to put a lot of effort into preparation.  I’d like to ensure I’m using the best quality paint product I can buy.
Thanks,   Lou
    JDRHI | Dec 13, 2006 08:57pm | #1
    I'm not a painter....but it has been my experience that all oil base paints yellow with time.
    You might be better off to consider a latex paint with several coats of clear polyurethane to finish.
    Happy
    Holidays
    1. Piffin | Dec 13, 2006 10:22pm | #2
      Poly over paint will look even more yellowed because it fiolters the light on the way through. Fine on yelllow wood, but it really stands out on white paint.My choice for years on painted cabinetry is Benjamin Moore Satin Impervo
        JDRHI | Dec 13, 2006 10:42pm | #3
        I prefer Satin Impervo as well. But I have used it throughout my own home and can attest to the fact that it yellows over time as well.
        In rereading my original response, I realize I should have specified water based poly.
        I have had success with this process.
        Happy
        Holidays
        1. Piffin | Dec 13, 2006 11:07pm | #4
          maybe a specific brand then. I have seen water based poly yellow white paint immediately
  2. jackplane | Dec 14, 2006 12:06am | #5
    IME, there's no such product. The only way would be to melt in some lead to your white paint. Lead can be  toxic of course.
  3. stinky | Dec 14, 2006 12:24am | #6
    try water base paint..then clear coat with water based lacquer. there ya go. tony
  4. Catspaw | Dec 15, 2006 04:24pm | #7
    Lou,
    Check out this bulletin from Benjamin Moore regarding this subject:
    http://www.benjaminmoore.com/PDFarticles/1033/Yellowing.pdf
    Rich
    1. DonCanDo | Dec 15, 2006 09:50pm | #9
      Thanks for that link.  How did you find it?  Is there a list of technical bulletins somewhere on their website?
      -Don
      1. Catspaw | Dec 16, 2006 05:12am | #10
        Here is the link to Benjamin Moore technical bulletins:
        http://www.benjaminmoore.com/wrapper_pg1art.asp?L=prof&K=contrt&N=con&art=2.3.3
        1. DonCanDo | Dec 16, 2006 05:24am | #11
          Thanks.  It looks to be easy to find in hindsight.
          Part of my problem was that http://benjaminmoore.com directs you the American website while http://www.benjaminmoore.com directs you to the Canadian website.  You would think one company, one website.  But no, 2 entirely different websites!
          -Don
  5. user-64511 | Dec 15, 2006 09:18pm | #8
    Try the MURALO ULTRA waterborne high gloss trim paint. I have been using it for about 12 years. It is the best paint I have ever used. Gloss as good as oil (Impervo), goes on beautifully, does not yellow and doesn't chip like oil paint. It wiil darken slightly with age but the only way uou will know is if you put on a fresh coat beside it. Buy the best quality brush and add a little "Flood's paint conditioner". Easy clean-up and no odor. (I believe it can be sprayed but I haven't tried that yet).
FHB Podcast Segment: Embodied Greenhouse Gas Emissions and the Building Codes
