Best Porch Spindle Material?
carl10 | Posted in General Discussion on March 11, 2009 04:52am
I have an 1870’s house that I have added a large covered porch to the rear. I plan on using a turned spindle for the rails. I need over 200 spindles and assumed I should use treated.  Checking the stock at the local home centers, I was quite dissappointed at the quaility of the treated stock (there was significant chipping and tearout from the turning).  There was a night and day diffrence compared to interior spindles (of course those were 2x-3x in price). There are not any close lumber yards to check thier stock.
I have used treated wood on some window sills I replaced and although the wood seemed dry enough I had paint adhesion problems.
If I am going to paint these spindles does it matter what material is used?
Thanks,
Carl
    Jeff_Clarke | Mar 11, 2009 05:14am | #1
    Use WR cedar or Spanish cedar - you should have CinderWhit quote it - this is their line of business, especially c. 1870:
    http://www.cinderwhit.com/stock.html
    By the way, in general, shopping for much of anything to go into an 1870s house at the home centers is suspect.   The learning curve to know what to do - and not do - is actually pretty steep (I've been at it only 30 years).
    Edited 3/10/2009 10:23 pm ET by Jeff_Clarke
    JDRHI | Mar 11, 2009 05:17am | #2
    "Treated" as in pressure treated?
    For porch spindles?
    Hell no.
    Cedar.
    J. D. Reynolds
    Home Improvements
    Proud recipient of the BT 'Truth In Print' award.
