Best Ridge Vent
JohnT8 | Posted in General Discussion on July 23, 2008 09:13am
You might try posting your question in a different folder.  You posted it in the “breaktime fests” folder, which is about parties and get togethers.
“A little ‘enthusiasm’ and all problems seems small!”
  1. wane | Jul 23, 2008 09:23pm | #1
    well, I saw it anyway, so .. definitely not alluminum, steel holds its shape better, and not the kind with the plastic end plugs, the squirrels call them "doors" ...
  2. IPE77 | Jul 24, 2008 02:10am | #2
    I use CoraVent Extreme 5 and make my own lead end caps. It also has a flap designed to keep snow out and leaves a more pronounced sharp ridge than the roll ones
Podcast Episode 691: Replacing Vinyl Siding, Sloping Concrete, and Flat vs. Pitched Roofs
Listeners write in about ground-source heat pumps and weatherstripping and ask questions about engineered siding, concrete that slopes the wrong way, and why houses have pitched roofs.
  • A Postwar Comeback
