Best way to attach TJIs to a blind rim joist?
I have a floor to build where I’m using TJI’s and OSB Rim but on one side this bumps up against the wall of the building I’m adding onto so that I can’t shoot through the rim into the TJI’s. I carry this load at the junction of the new and old building with a big glue lam that these TJI’s ride accross. I’m concerned about preventing any roll in the TJI’s do I need to use hangers or blocking here along this rim? or can I just glue an shoot down into my glue lam, and glue and shoot the 3/4 t / g sheeting going over
thanks for the thoughts.
jon
http://woodbywy.com/literature/TJ-9001.pdf
This will show you how to fasten, and how to properly block those areas. TJI's are easily crushed, the webbing has to be fortified into a solid carrying piece where there is a point load over the beam.
