Best way to check for square
cwc09 | Posted in Construction Techniques on February 9, 2009 01:02am
What do you guys think is the best way to check for square in a situation like a replacement window install?
I know you’re supposed to measure diagonally from corner to corner – but usually the lower corners of my windows sit down below the original/existing interior sill. So I like to measure diagonally from corner to corner inside the frame.
My issue is that butting the end of the tape into the corner can’t be that accurate and “cutting an inch” (or measuring from the 1 inch mark instead of butting the tape into the corner) gets tough to do on large windows when you’re by yourself.
Would I be better off using a 3-4-5 method?
Any other techniques / advice?
  1. TomT226 | Feb 09, 2009 02:07pm | #1
    You can rip some 1X or ply into two thin strips, butt the ends on one diagonal, mark it, flip it to the other side, butt it and see if the marks line up.  There's a little sliding clamp thing you can buy from Rockler to make a sliding "story stick."  Works great for building cabs and it should work for windows, etc.
  2. Marson | Feb 09, 2009 03:06pm | #2
    I check for square by looking at the reveals. If the sash fits the frame, then all is well.
    Otherwise just use a framing square.
  3. FastEddie | Feb 09, 2009 04:02pm | #3
    butting the end of the tape into the corner can't be that accurate
    That depends on if you want to get the actual measurement, or just compare teh two diagonals.  As long as you butt the tape to the corner the same way both times, the dimension will accurately show the variation of the diagonals.
    1. AitchKay | Feb 09, 2009 04:55pm | #8
      Right.And the new, stiff tape measures that are out now make it a lot easier. I remember when 1" wide tapes first came out -- that was a big deal!Now even 1” tapes feel wimpy to me -- I currently use a Fat Max, and like the way it stays stiff in those “push” applications like squaring up, getting inside dimensions, etc.AitchKay
    Sphere | Feb 09, 2009 04:14pm | #4
    Use a square. equal diags can still be a paralellagram.
    1. Hiker | Feb 09, 2009 04:46pm | #5
      Trapezoid
        Sphere | Feb 09, 2009 04:55pm | #7
        http://en.wikipedia.org/wiki/Trapazoid
        http://en.wikipedia.org/wiki/Parallelogram
        which one has eq. diags?Spheramid Enterprises Architectural Woodworks
          Dam_inspector | Feb 09, 2009 05:00pm | #9
          I got nothing. Hikers been trapped.Edited 2/9/2009 9:03 am ET by Dam_inspector
          Edited 2/9/2009 9:05 am ET by Dam_inspector
        2. Hiker | Feb 09, 2009 05:05pm | #10
          The only time a parallelogram can have equal diagonals is when it is a square or a rectangle.
          A trapezoid can equal diagonals if the "bottom" edge is equally longer than the top edge on both sides.    I  would draw picture but posting pics is beyond my skill set.
                    Top 10 units
               __________
          ________________
          Bottom 16 units, 3unit on each side of the top .  The diagonals are the same, but not square.
            Sphere | Feb 09, 2009 05:11pm | #11
            I'll get back to ya, work calls.Spheramid Enterprises Architectural Woodworks
        3. rasconc | Feb 09, 2009 05:11pm | #12
          Neither I believe, all Wiki said was a parallelogram diagonals intersected.  Note the single hash on one dia and double on the other.  A square is a parallelogram though.
          Cheers, BobFor those who have fought for it Freedom has a flavor the protected will never know.
          1. JHOLE | Feb 09, 2009 05:17pm | #13
            Right.Remodeling Contractor just on the other side of the Glass City
            Sphere | Feb 09, 2009 06:43pm | #14
            I stand corrected, well, not actually, my back is still crooked. LOL
            Need to not do math and geometry before the coffee kicks in.Spheramid Enterprises Architectural Woodworks
        4. DanH | Feb 09, 2009 08:02pm | #16
          Hiker's right -- the trapazoid has (or at least can have) equal diagnonals.  But with a window one assumes that opposite sides are equal length, so you can't have a trapazoid.
          People do get burned, eg, laying out a foundation with the equal diagonals technique, if they don't take equal care to assure opposite sides equal.
          1. cliffy | Feb 09, 2009 08:05pm | #18
            If your rough sill is a little long or short you get a trapezoid. Have you found that yet?
            Have a good day
            Cliffy
          2. DanH | Feb 09, 2009 09:31pm | #19
            I assumed the issue was about squaring up a factory window. If the window's a trapezoid out of the factory you're buying from the wrong factory.
          3. cliffy | Feb 09, 2009 09:56pm | #20
            I assumed he was refering to the window opening.  Right  on about the wrong factory.
            Have a good day
            Cliffy
      2. cliffy | Feb 09, 2009 08:03pm | #17
        Nice one
        CHave a good day
        Cliffy
    PeteDraganic | Feb 09, 2009 04:54pm | #6
    Replacement windows are the easiest.... slightly open the sash (top or bottom) just enough to see a sliver of light between the sash and frame.  then, use your eye to make sure that sliver is even across.
    Furthermore, the window openings are typically pretty square in the first place.... and replacement windows are a bit forgiving even when they are not perfectly square.
    I refuse to accept that there are limitations to what we can accomplish.        Pete Draganic
    Take life as a test and shoot for a better score each day.          Matt Garcia
  6. Piffin | Feb 09, 2009 07:56pm | #15
    do you have a true frameing square?
FHB Podcast Segment: Embodied Greenhouse Gas Emissions and the Building Codes
