Best way to cut steel siding?
arcticcat | Posted in Construction Techniques on July 24, 2005 07:46am
Hey all, I’ve got to cut in a 6-0 patio door in an existing wall with steel siding.  Was wondering what other guys use for cutting steel siding.  I’ve used sawzalls, & circular saws before, but I do have a 4 1/2″ grinder now.  Would a thin cut off wheel work for this?
Thanks, Mike.
  1. GCourter | Jul 24, 2005 07:11pm | #1
    Electric sissors do a find job,  lessens the chance of eye injury and will not shake the building down.
    1. arcticcat | Jul 28, 2005 06:14am | #12
      Thanks for the replies all.  Ended up using my circular saw with an old marathon blade(and safety glasses).  Made a nice cut.  Might check into a narrow cutting wheel for next time.
      Mike
  2. Hooker | Jul 24, 2005 07:21pm | #2
    It's been a while, but I have used a grinder for cutting the siding.  Assuming you'd like to not remove the siding, correct?
    I'm trying to remember exactly what the wheel was.  Would a diamond cutter wheel work?
    I know the grinder worked fairly well, just cant figger the wheel.  Sorry.
  3. Mac2 | Jul 25, 2005 02:01am | #3
    That thin cutter will do fine---with one caution. If the wheel is twisted or skewed in the cut, it will either wear off very quickly or disintegrate. So, safety glasses, and a steady hand.
    I decided to stop taking life so seriously, it is, after all, only temporary.
  4. blue_eyed_devil | Jul 25, 2005 02:46am | #4
    I used to use a fine tooth blade in my power saw for aluminum siding. We always mounted the blade backward.
    I suspect that todays carbides would do a magnificent job on steel. They cut nails real good.
    blue
    1. Danusan11 | Jul 25, 2005 04:53am | #5
      Thats the way I always did it fine tooth backwards
  5. jericho | Jul 25, 2005 05:16am | #6
    arcticat,
    ever try a nibbler. they make them for different thicknesses. you'd probably be looking for an 18 gage corrugated nibbler. it operates with a punch and die in the cutting head. its fast, clean, and no vibration.
    j
    1. Woodbutcher | Jul 25, 2005 08:14am | #8
      A nibbler will only work for the flat surfaces. it won't be able to cut the "hook & lap" every 8"  (assuming it is "lap" steel siding, and not the horizontal stuff)
      I'm voting for the grinder with a thin metal cutting disk.  Just be digilant about protecting everything that might be damaged by the sparks and chips. (like yourself, for instance)
      1. cicero | Jul 25, 2005 11:48am | #9
        That is what I use,a 1mm cut off wheel,as do all my mates in engineering.
        Just don't forget safety glasses.
      2. jericho | Jul 25, 2005 02:40pm | #10
        mark,
        the nibbler for corrugated should be able to handle this situation.
        http://www.feinus.com/p/newnibbler/nibblermain.htm
        j
  6. level1 | Jul 25, 2005 07:05am | #7
    If you use a grinder, be careful of what the sparks hit.  They will pit glass and can embed themselves in the finish on the siding causing premature rust.
  7. arrowshooter | Jul 25, 2005 04:30pm | #11
    I bought the Sears twin cutter (show stopper as shown on the website below) at Sears for $160. +-. It will cut almost anything metal and does a real smooth job.
    Ive used it for Re-bar ,angle iron, waterpipe, and metal siding .
    You might not want to spend that much for a one time deal but it's a great tool to have around.
    http://www.popularmechanics.com/home_improvement/tools/1274261.html
