Its new construction 1800sqft +, here in the North Carolina conventional heat pumps are the norm. Would like to use gas for additional backup in system. What are some good questions to ask the guy and how to know if this guy is on the up and up.
TVM, Roger
Upgrading the footings and columns that support a girder beam is an opportunity to level out the floor above.
What part of NC. If it's WNC, I got a name.
What part of western N.C. are you from? I am in Franklin and know someone you should run away from.
HI, I posted about finding a HVAC person, live in Hickory, NC.
thanks, Roger
Sheesh, both youse guys is neighbors. Asheville. I-40 Exit 53B. Send an email along and I'll continue this in private.
Best way is to go to the library and net and read/study, then get a 609 license for $25, then you have yourself as your own expert.
Find the local manufacturer's distributor for a few brands that you might be interested in. If you don't have any in mind, my preference would be Heil, Trane, Carrier and Armstrong (for forced air furnace/ ac combo type systems). There are about a dozen well established manufacturers and everyone will have different preferences. Others you might consider are Lennox, American Standard, Ruud, York and Bryant. Ask the distributor who they recommend as a contractor. A good contractor does good work and makes the product look good, and vice versa. Call them and get references, for the last 4 jobs, for instance and follow up. Call the customers.
Once you find someone, some good questions to ask are:
What capacity (size) do you recommend for my house? How do you size the system? Can you give me a copy of the calculations? How do you size ducts? At what velocity do you pick supply registers? How do you seal ducts? How do you insulate ducts? How much flex do you use? A good "litmus" question is: Wouldn't a bigger air conditioner be better?
A good HVAC guy will NOT answer some of the questions, like the first one. If the answer to last one is "yes", keep looking.
