Better bathroom sidewall vent
JohnT8 | Posted in Energy, Heating & Insulation on October 13, 2004 06:14am
Installing a quiet Broan bathroom exhaust fan.  Fan is located about 2.5′ from outside wall and will be punching straight out that wall (2×4 framing).
My question is, does anyone have a source for a better quality 3″ sidewall vent?  I went to a couple of the local big box stores and my only choice is a single-flapper dryer vent, or a triple flapper fan vent.  Neither one of which looks very impressive.
I really don’t like the idea of a 3″ hole in the wall, but have to in order to remove moisture from this bathroom.  But I’d like to think the flapper will be of good enough quality to close when the fan isn’t on (don’t want a constant thermal siphon).
  1. DanH | Oct 13, 2004 10:03pm | #1
    If exterior appearance isn't an issue, there are "coffee-can-on-an-elbow" vents that are probably the most reliable and best at sealing. Ugly as sin, though.
    1. JohnT8 | Oct 13, 2004 11:43pm | #2
      I think I put one of those on Mom's dryer vent (she was afraid a snake get in with the old one).  The air pushes up a little cup?  Hmm... that is a bit larger than I had in mind.
      Even if I had a good, regular style dryer vent, I'd be happy with that.  Just enough seal that the warm air from the house isn't siphoning out the vent.... but not so tight that the fan has trouble pushing it open.jt8
      1. DanH | Oct 14, 2004 04:42am | #4
        The one for bathroom vents is similar to the dryer one, but a little smaller, and with counterbalance springs so that the fan doesn't have to work so hard.
  2. mikerooney | Oct 14, 2004 01:30am | #3
    I can't, for the life of me, remember the name; but, I put in a through the wall vent, years ago, that was motorized, and weatherstripped. Very well made (and accordingly expensive).
    It was in an ad. in FHB.
    Maybe someone else will remember.
  3. csnow | Oct 14, 2004 10:12pm | #5
    Maybe you could use this:
    http://www.tamtech.com/preventilator2.htm
    1. JohnT8 | Oct 14, 2004 11:06pm | #6
      Looks like an insulation upgrade to a standard wall-mounted exhaust fan.
      So then you're thinking, do I go with a poorly insulated 3" hole or a somewhat insulated 10" one?
      Edited 10/14/2004 4:07 pm ET by JohnT8
      1. csnow | Oct 15, 2004 12:13am | #8
        "So then you're thinking, do I go with a poorly insulated 3" hole or a somewhat insulated 10" one?"
        Those things seal really tight.  Top quality goods.
        They also sell a backdraft stopping device that you could use with a standard fan.
        http://www.tamtech.com/cape_damper.htm
        Edited 10/14/2004 5:14 pm ET by csnow
  4. greggo | Oct 14, 2004 11:43pm | #7
    John :
    Did you check out Mid Americas product line at the big box stores,they are pretty decent(http://www.tapcoint.com)also http://www.efi.org has a coupler looking device that the interior of it collapses when the fan is off,so no outside air can come back in the house.I don't know if you can get one thru a sidewall install job ,you might be able to squeak one in.
    Greg
  • xoxo test post 3
  • xoxo test post 2
  • xoxo test post 1
