what is the going rates for the installation of hardi plank siding job is 35 square I built the house so I want to make some money but I also want to be fair to customer any response is helpful i live in maryland
Prescriptive codes don't address the connection at less common angles, so base the connection off more typical ones using bolts, structural screws, blocking, and steel tension ties.
All materials and supplies such as blades and caulk....
X 2....great price for customer.
X 3....great price for contractor.
X 2.5...fair price for both.
You need to get some square up everyday you work... 5 square a day, you and your crew will be tired, and well paid.... 2 square a day and you will sub it out next time.
near the stream,
aj
*rafterman. Reminds me of top gun. Anyway... there is a book out called the national cost estimator. There are several versions out there. I would get the one that is titled renovation & insurance estimator. In this book are listed prices both material & labor for all trades as well as area modification factors. This book can be found at all major bookstores either in home improvement or engineering sections. It comes with a computer disk wich has the books contents on it. The program is a little strange at first but you can print estimates directly from the computer. Hope this helps.
