Birds mouth cut question
pizza | Posted in General Discussion on January 15, 2018 08:39am
Hi. When cutting the birds mouth, I see that most people don’t account for the sheathing applied on the exterior wall. Is that normal or does it just depend on how you are going to finish the eaves?
I’ve seen some make the seat cut of the birds mouth a little wider, say 1/2″ if using 1/2″ sheathing. But most just cut the bird’s mouth so that if butts right to the top plate with no gap for the sheathing.
Any suggestions? What’s typically done?
I will be building a 10:12 shed roof (using 2″ x 6″ rafters and a 2″ x 8″ ridge beam) with an 18″ overhang and plan to leave the rafters exposed, not closing it all in with a soffit.
I do not want to notch the sheathing around all of those rafters.
Thanks to all in advance.
  1. oops | Jan 15, 2018 12:04pm | #1
    Sheathing need not notch around rafters.  Simply butt sheathing (and siding) to the 2x6 bird blocking.
    1. pizza | Jan 15, 2018 12:22pm | #2
      birds mouth
      Hi . Thanks for the reply but I can't picture what you are saying. What is bird blocking?
      1. oops | Jan 15, 2018 10:25pm | #4
        bird blocking
        That is simply blocking between the rafters at a point located at the outer edge the wall
        that closes the space between the rafters, wall and roof deck. If the blocking is located
        such that the inter edge of the blocking and the outer edge of the top plate is aligned,
        the sheathing and the siding can be butted up to it. It eliminates the need for notching,
        and as the name implies, keep the birds out of the attic. :) The blocking can be plumb with
        with the wall or perpendicular with the rafters. Sorry, I can't do pictures.
        I think that there are pictures in the International Residential Code book.
    user-2409187 | Jan 15, 2018 02:06pm | #3
    I usually account for sheathing
    I notch for sheathing so that I have the full 3" at the top of the wall for nailing. Remember, among other things sheathing serves to negate sheer. For example, for 1/2" sheathing I make a 5/8" allowance.
    That said, in very steep pitch situation I take into consideration how much the tail end of the rafter may be weakend by taking off an additional amount for sheathing.
  3. oldhand | Jan 16, 2018 09:52am | #5
    slow down..
    Put the wall sheathing on before the rafters.
    1. calvin | Jan 16, 2018 10:22am | #6
      Shoot
      Square and sheet the wall before standing it up......
      1. DanH | Jan 16, 2018 05:01pm | #7
        But why shoot the poor bird?
        1. calvin | Jan 16, 2018 05:54pm | #8
          I dunno
          Can't see it from my house.
