You have to take another look at the depth control as this is the only differance between biscuit size. Look to see if something has got jammed in the way of the slides.
Understand lumens, ceiling brightness, beam spread, tilt, and color options to make a wise choice on a common fixture that can range from $75 to $750 or more.
Have a little used Porter Cable biscuit cutter that I need to use a lot just now. Can't get it to cut an larger than the smallest (0) biscuit. Made all the adjustments allowed but it doesn't change anything. Works perfectly in the smallest setting. Any suggestions? Sacie L.
