Biscuits on thin stock/Domino on plywood
BigMish | Posted in General Discussion on May 28, 2008 07:34am
I’m considering buying my first biscuit joiner. I never considered that there may be a minimum width of stock that is usable with this tool until I was reading the description of these special face frame biscuits (http://www.amazon.com/Porter-Cable-5563-Joiner-Biscuits/dp/B0000222ZC/ref=acc_glance_tool_ai_-2_2_tit) where they said they could be used on stock as small as 1 ½â€. That’s very thick! Can a biscuit joiner really not be used on stock any thinner than that?
I’m also considering splurging on a domino joiner. Anyone used one of these with ply wood? I wonder how well it woks joining into plys end grain…
  1. john7g | May 28, 2008 07:41pm | #1
    I think they got their T & W mixed up, as in as narrow as 1.5" wide.
    I've used biscuits on stock as thin as 5/8".  concerns when it gets that thin is telegraphing through if you're staining but not an issue if painting.
    FatRoman | May 28, 2008 09:33pm | #2
    Domino will work just fine on plywood, though it's better on 3/4 than 1/2
    http://festoolownersgroup.com/index.php?topic=1697.0
    http://festoolownersgroup.com/index.php?topic=1758.0
    http://festoolownersgroup.com/index.php?topic=2350.0
    http://festoolownersgroup.com/index.php?topic=1521.0
    Lots more there as well. I don't think you can search without signing up, but it's free to do so.
    'Man who say it cannot be done should not interrupt man doing it' ~ Chinese proverb
    ToolFreakBlue | May 29, 2008 12:10am | #3
    Like John said, 1 1/2" wide stock. The "FF" biscuits use a 2" cutter not the 4" as for the 20s, 10s and Os etc. Smaller cutter means shorter biscuit slot (as in length) allowing to cut a slot in 1.5" wide stock's end grain without blowing out the exposed edges. The joiners are most user friendly for 3/4" thick stock but allow to go thinner if needed.
    TFB (Bill)
  4. fingers | May 29, 2008 01:10am | #4
    Sorry, this is going to sound like a typical Breaktime reply.  You want to buy a biscuit joiner and I'm going to tell you to look into a Kreg jig.
    Its cheaper, lots quicker, no clamping while glue drys, and if you plan it right, you can usually hide the pocket hole.  The only advantage to a Biscuit machine is if it has to be invisible.
      Sphere | May 29, 2008 02:18am | #5
      No, no, no...a typical BT reply is get all 3!Spheramid Enterprises Architectural Woodworks
      New book alert; Eckhart Tolle "A new earth"
      A must read.
  5. Dave45 | May 29, 2008 02:50am | #6
    What will you be joining?  If visibility is an issue, go with the biscuit joiner.  If it isn't, get a pocket joining system.
    I build cabinets and furniture and have used everything from dowels to biscuits to pocket screws.  My dowel jig has been collecting dust in the drawer for several years and - since I got the Kreg K3 pocket screw kit a couple of years ago - my biscuit joiner spends most of it's time on the shelf.
    It used to take me a couple of hours to make a biscuited faceframe and I had to leave it in the clamps for several hours before I could put it on.  Now, I can make the same faceframe with pocket screws in less than an hour and install it immediately after I drive the last screw.
Grout-Free Shower Panels
  • A Postwar Comeback
