bit for boring thru ipe
joewood | Posted in Construction Techniques on July 12, 2005 04:16am
OK folks, I have about 56 1/2″ holes to bore 3.5″ thru ipe 2x4s.
I think my best choice would be those Pilot Point bits by DeWalt, or maybe a brad point. Gonna do this on a drill press. Which other type bit would you think might work ?
Forget wing bits or forstners ..
  1. jerseyjeff | Jul 12, 2005 04:31am | #1
    I found that the pilot tip dewalt bits tend to bind a bit in ipe and leave an ugly tearout....  have you thought about a SHARP self feeding auger bit (that you can resharpen halfway through the job)
    1. joewood | Jul 12, 2005 04:59am | #2
      you know, I've never tried an auger bit in ipe, I'd think the self feeding action would bind up in that hard wood.
      I don't care about tearout, these will be deck railing posts and the tearout will be up against the facia.
      have you ever tried a 1/2" auger in ipe ?
  2. davidmeiland | Jul 12, 2005 05:53am | #3
    I'd definitely go with a carbide-tipped brad point. A self-feeding auger would be scary, especially on a drill press, although you could loosen the belt to act as a clutch.
    1. TJK1141 | Jul 12, 2005 08:19am | #4
      I agree with davidmeiland - the brad-point carbide bits are best and will leave the cleanest holes.Just don't drop them or let the tips hit the drill press table. You will cry ($$$).
  3. Bender | Jul 12, 2005 02:03pm | #5
    I used the Milwaukee forstner-like bits with the screw feed replaced by holesaw (1/4 in) pilots to let me control the feed rate.  Put it in a drillpress, backerboard, sharpen often, shopvac hose taped nearby, clean holes in and out.  Worked for me on about 210 1 3/8 holes through 4x4 ipe posts.
    Fitter
  4. WorkshopJon | Jul 12, 2005 04:41pm | #6
    Joe,
    56 holes with a drill press?
    A plain old standard drill should work fine.  A cobalt should last you for at least 5000 holes before it needs a re-sharpening, and they're not that expensive.
    WSJ
  5. mike4244 | Jul 12, 2005 07:43pm | #7
    I have drilled holes thru ipe for bolts with an ordinary spade bit. No problems, easy to file a new edge on these bits when the going gets slow. If I recall, I got about 10 holes before I refiled the bit.
    mike
