blade or blade care for laminate floors
jimatgreatwhite | Posted in Tools for Home Building on March 16, 2009 05:20am
I’m sure this has been gone over in the past,here goes again though.
Is there a saw blade that doesn’t dull after 200 square feet o laminate flooring or is it just gummed up?
If it is gummed up what is the best way to clean it up?
I’ve been gone for quite a while forgive me if I’m beating a dead horse with this question.
Jim at great white
    Dinosaur | Mar 16, 2009 06:01am | #1
    In order:
    No. But a triple-chip blade will last a bit longer than other types.
    Oven cleaner and a stiff brush. When this no longer works, send it out to be resharpened.
    When I bid a laminate floor job, I add a $100 charge for each 500SF of flooring for blade resharpening and replacement. I use Exchange-a-Blade blades for those jobs; costs me about $90 to buy the first one and $48 to swap it out for a re-sharpened one.
    Dinosaur
    foolish men call Justice....
  2. TomE | Mar 16, 2009 06:07am | #2
    laminate is very abrasive, dulls the blade.
    Triple chip grind will last longer than ATB but will still dull.
    Just did 1600 sf of laminate and the Freud Avanti TCG blade is still servicable.
    1. KenHill3 | Mar 16, 2009 06:20am | #3
      On laminate flooring I do all I can to do my cuts with an inexpensive blade in my skillsaw. 99% of the cuts won't show, so you can cut with whatever. Yup, the wear layer is aluminum oxide and eats blade teeth.
  3. Marion | Mar 16, 2009 06:34am | #4
    I use jigsaw to cut laminate. Speed square to run plate against. The dust is not as bad as with mitersaw and cutting can be done without going to other room. Blades are a lot cheaper than the 10" miter and chipping can't be seen.
  4. [email protected] | Mar 16, 2009 06:45am | #5
    I'll second the jigsaw recommendation. There are some blades with the teeth reversed, that do a really good job of cutting it without chipping.
      Sphere | Mar 17, 2009 03:09am | #9
      Just to add about the downcut jig saw blades, they work a LOT better with the orbital action OFF.Spheramid Enterprises Architectural Woodworks
      1. jimatgreatwhite | Mar 17, 2009 06:22am | #10
        thanks all
        now I know I' not doing anything wrong.
        jim at Great white
      2. jimatgreatwhite | Mar 17, 2009 06:24am | #11
        Thank you everyone my thinking is confirmed. Laminate requires blade allowance. Now how do I get the extra money out of my wife for this job?;)Jim at Great white
        1. GregGibson | Mar 17, 2009 11:29am | #12
          Why, nookie, of course !Greg
        2. VMackey | Mar 17, 2009 11:18pm | #13
          That is exactly what I do. Price in one new, cheap as possible, blade per job. I usually end up keeping it on hand as a beater blade. If I remember, I also mark it as "flooring", as once dull, they seem to cut the laminate flooring just fine, it's other materials that it give an unacceptable cut on. I run it through as much flooring as possible then toss is when it starts working the chop saw too hard. Vic
  5. chairmon | Mar 16, 2009 07:17am | #6
    Jim how big of a job?
    What I have found works best is a cheep riobi cordless saw. Tape the metal corners and drag it with you as you go. The blades are $10.00 or so and last several 1000 ft before they are too bad to use. We have laid 65 to 70,000 sq ft this way.
    Thanks Craig
  6. andyfew322 | Mar 16, 2009 07:46am | #7
    for gum from a laminate floor, im not too sure for cleaner, but i know with pitch, Simple Green and a nylon brush works well
    http://www.cocoboloboy.webs.com
  7. Scott | Mar 16, 2009 07:17pm | #8
    I ruined my nice Tenyru blade that came with the Makita by cutting laminate. The good news is that the sharpening company got it as good as new.
    You can also use those el-cheapo "Exchange-A-Blades" if a dealer stocks them.
    Scott.
  8. Dave45 | Mar 18, 2009 02:49am | #14
    For the past few years, I've cleaned my saw blades in disposable pizza pans I get at the grocery store. Put a couple of blades in the pan, cover with Simple Green, wait ~5 minutes, and scrub them with an old toothbrush.
    For router and shaper bits, I use Simple Green in old butter tubs.
    Regular cleaning cuts way down on trips to the sharpening shop.
  9. jnsn | Mar 21, 2009 11:41pm | #15
    I find that the worst part about laminate floors is the DUST. To that end I use jig saws wherever possible. You can double the life of the blade by attaching a layer of plywood under the base. After that part of the blade gets dull, remove it and use the rest off the blade depth. Also we use cheaper 7 1/4 skill saw blades in the table saw when we are forced to make multiple rips. If you do a lot of laminate you can also purchase a cutter (like a large paper or shingle cutter) which will cut with no power or dust.
Deck Details for Durability
Freestanding with boxed stairs, this small deck is full of ideas for a long-lasting entry that will look great for years to come.
