blade stuck in 7 1/4 porter cable saw
Craig530 | Posted in General Discussion on December 30, 2007 07:08am
About a year ago I replaced my old Milwaukee circular saw with a new Porter Cable that has a wrenchless blade nut.  It ( the blade nut) was a great improvement allowing blade changes without keeping a 9/16 ths wrench in your pouches.  However, the last time I tried to remove the blade nut it just spins loosely, without moving the bolt, and yes  I am holding the spindle lock and have been a carpenter for over 20 years so I can change blades in my sleep.  If anyone has a fix for this problem let me know.
  1. andyfew322 | Dec 30, 2007 07:13am | #1
    did you try throwing it off the roof swearing. :)'
    It takes studs to build a house
    1. Craig530 | Dec 30, 2007 07:32am | #2
      only swearing that I will never buy another saw with a wrenchless blade bolt
      1. andyfew322 | Dec 30, 2007 08:23am | #3
        lol
  2. USAnigel | Dec 30, 2007 10:10am | #4
    Maybe you can "spin" the blade in the undoing direction. Have someone hold the saw body and you place a "spike" in the blade some how and give it a thump. Get the idea?
    1. Craig530 | Dec 30, 2007 06:06pm | #7
      lock washer has flat sides on not a round hole spinning blade can only spin shaft not retaining bolt
    davidhawks | Dec 30, 2007 02:59pm | #5
    Try an impact gun.  The "slapping" action will often knock the bolt loose.  Has worked for me in the past on older saws w/out the shaft-lock.
    Good luck.
    Live in the solution, not the problem.
    MarkH | Dec 30, 2007 05:00pm | #6
    I'd take it to the service center myself.  I think that was a problem, also you should see if it was recalled for the guard sticking.  Mine is a bit odd about blade changes too, but it works.  I don't really see an advantge to it.
  5. Notchman | Dec 30, 2007 06:23pm | #8
    This won't help your current dilemma, but as I live in the PNW where it tends to be damp in the winter, I always give removeable bolts and nuts a dab of Never-seize compound before reassembly.
    Personally, I'm not too fond of tool-less blade changing systems.  The last one I dealt with was on one of my sawzalls....the sleeve inside had shattered and getting the blade out and getting it apart was a real MFr.
  6. Cashmaccoll | Feb 28, 2018 02:20pm | #9
    Same Issue!
    So, I have the exact same issue. Were you able to finally remove the blade and get the quick re;ease working again?
    thanks!
