BLEW UP MY WOBBLE LIGHT
maxp | Posted in General Discussion on February 10, 2007 06:48am
The Wobble LIght has an auxilary outlet to string more lights togather- Well I somehow ran a cord to a mitersaw and I guess blew it up – Has anyone other than me overloaded one and if so what is the fix? I had hoped for a reset or a fuse but haven’t found one-
    McDesign | Feb 10, 2007 06:55am | #1
    Ahhh - you should have gotten a WEEBLE light
    "Weebles wobble but they don't fall down"
    Forrest - I'd take that sucker apart
  2. DavidxDoud | Feb 10, 2007 08:46am | #2
    what type of bulb does your unit use?
    did it just flash and go out? is there no power out now?
    they are pretty simple machines -
    I think McDesign has the right idea -
    "there's enough for everyone"
  3. Jer | Feb 10, 2007 03:53pm | #3
    You blew your wobble?!! Dang son...I've blown my wad, but never my wobble!!
  4. MisterT | Feb 10, 2007 04:18pm | #4
    are U the same guy who bought the floor display from Home Despot??
    Welcome to Breaktime
    Home of
    The Aristocrats
    MarkH | Feb 10, 2007 04:54pm | #5
    Call 877-707-0800 for the service department.  Maybe they can help.  As far as I know there is no fuse or breaker inside them.
  6. teachshop | Feb 11, 2007 02:18am | #6
    I bought one at Home Depot so I could tape and paint my garage.  Perfect because I wanted to finish the ceiling before installing the 8' fluorescents and it was miserable in there with just to light bulb sockets.  I then managed to knock it off my bench top the first day.  Apparently gravity still applies to wobbles.
    The bulb did not appreciate that type of treatment, so I headed back to HD.  Guess what, HD doesn't stock the fluorescent bulbs. I had to order them on line. They came in just as I finished painting, perfect.
    The only good news is I ordered a bunch so I can't continue to check for any holes  in the gravitional field around my light.
  7. RW | Feb 11, 2007 03:16am | #7
    I've had it open. There's no fuse. Best you can try is pop the screws on the bottom and see if a wire came loose somewhere obvious.
    Real trucks dont have sparkplugs
    1. maxp | Feb 11, 2007 06:27am | #8
      Thanks for most of the input- To answer a few questions , the bulb is 175w metal halide- seemed like a breaker at the panel kicked but it hadn't- not sure about the flash. No power in or out now- bulb shows no sign of damage
      No not the guy who bought the display at HD but would have if it was on the 75% off table-
       I did call customer service and was treated great-they are sending me a circuit board, the recommended fix.....Even with my blown webble wobble I would still highly recommend this light, pretty darned handy
      1. RW | Feb 11, 2007 07:33am | #9
        I like both bulbs but bout died when I found out what a replacement MH bulb goes for. You dont want to break that. I have no idea what the flourescents are. I had my electrician get mine for me since he got a  break on the cost and it was still $40.Real trucks dont have sparkplugs
