I’m adding a front entry to my house that has a concrete foundation. For ease of installation I’m planning to use a block foundation for the entry. What is the best way to tie this to the concrete foundation?
![](https://images.finehomebuilding.com/app/uploads/2015/11/04132457/linoleum-vynyl-main-thumb-16x9.jpg)
If you’re looking for inexpensive flooring, especially in a potentially wet area such as a kitchen or bathroom, you’re probably going to consider linoleum and vinyl
I'm adding a front entry to my house that has a concrete foundation. For ease of installation I'm planning to use a block foundation for the entry. What is the best way to tie this to the concrete foundation?
Andy,
The best way to do this is to hire someone and sit back and sip cool drinks in the shade.
On the other hand, you could excavate to footer depth exposing the existing block on each side of the porch. Then bore holes in the block to accept two #6 rods of rebar. Hold the rebar 3 to 4 inches above bottom of footing and use concrete epoxy to secure rods in block. (Bore the holes 3 to 4 inches above footer bottom and slightly larger than rod.) Run the rebar around the footing and pour concrete...
