blocking in walls
drbgwood | Posted in General Discussion on April 17, 2006 12:35pm
I’m doing a remodel on a house in raleigh that has 9 1/2 ceilings.  My framer hasn’t said anything about installing purlins in the walls, but today I had another guy helping me and he said they were required in walls over 8 feet.
I looked in the code book, and the best I could find about it is that walls should have blocking top and bottom (sole and top plate) and blocking every 10 feet.
Do I need to put blocking in these 9′ 6″ walls?
raleigh, nc
  1. experienced | Apr 17, 2006 01:57am | #1
    Shouldn't need them unless you got bulkheads,valences that the wall cavities open into. Depending on the fire code for your area, you may need other types of closure for these cavities or floor cavities.
  2. jango | Apr 17, 2006 02:41am | #2
    I don't know about Raliegh, but in my 9 1/2-foot walls in Seattle, blocking was required.
  3. DanH | Apr 17, 2006 02:43am | #3
    This varies a lot depending on local code. Call your local inspector and ask.
    1. DanH | Apr 17, 2006 03:05am | #4
      (Also, it likely depends on whether the walls are insulated or not. Make sure you understand that detail.)
  4. Piffin | Apr 17, 2006 03:29am | #5
    Yes, over eight feet needs blocking
    1. experienced | Apr 17, 2006 03:40am | #6
      Folks:
      He has the code book for his AHJ and it says 10 feet!!  And if the wall is insulated, it may not need the blocking at all.
      1. Piffin | Apr 17, 2006 05:25pm | #8
        I knew he had the code book, but he reported a lack of experience using it leading to confusion. Since my past experience agrees with that of his helper, I reported based on that, rather thana code book I can't see.
    Matt | Apr 17, 2006 04:15am | #7
    I too build in Raleigh.  If you are talking about < 10' interior walls, no, they do not need blocking.  For exterior walls, in the corners or wherever a sheer panel is required, you need the blocking at the sheathing joints.
  6. PeteVa | Apr 17, 2006 06:56pm | #9
    The code book states the minimums allowed. If you only work to minimun acceptable standards and only expect those you hire to do the minimum then keep your code book handy and read it often.
    Blocking in any wall is a good idea. It keeps all the studs plumb and adds stiffness to the wall.
    Up in New England they strap everything and walls and ceilings seem to be much more crack resistant.
    1. Framer | Apr 17, 2006 07:56pm | #10
      "Up in New England they strap everything and walls and ceilings seem to be much more crack resistant."When did they start strapping walls?Joe Carola
      Edited 4/17/2006 12:57 pm ET by Framer
      1. oceanstatebuilderinc | Apr 18, 2006 01:33pm | #13
        I take it you didn't get that memo?
        1. Framer | Apr 19, 2006 01:15am | #14
          "I take it you didn't get that memo?"No memo. I don't strap but I know alot lot of people do but strapping walls is a new one.Joe Carola
  7. woodway | Apr 18, 2006 06:49am | #11
    The ten foot rule has been around for many years...Fire/Draft stop rule. Sounds as though NC has adopted the rule from earlier code. If the rule is in the code where your located then, no you don't need to install fire/draft stop in any of the walls that are less then 10 feet in height. However, the codes are rules for MINIMUM standards for health and safety. If you have the opportunity to install blocking then I would do it just as an extra measure to help stop the spread of fire within the walls.
    Stops can be any nominal 2X wood or sheetrock held in place by some mechanical means. Fiberglass insulation, if secured in place and not allowed to move, can be classified as a fire block if it completly fills the void and is secured against movement. Recheck your code book in your area to make sure this portion of prior code was also adopted in your local code.
    The rule for blocking applies regardless if the wall is exterior or interior. The blocking will, if it's 2X material, help make the wall somewhat stiffer.
  8. oceanstatebuilderinc | Apr 18, 2006 01:31pm | #12
    Purlining is not code, just good building practice. It keeps the walls straight and true, and also allows the wall to act in unison. I live/work in Wilmington NC, and I Purlin everything over 9 Feet. Some architects/ Design Firms call for purlin blocking in the design. Sounds to me like you have a quality minded framer. Will you be putting chair rail on these walls? If so, purlin everything.
    Ocean State Builders, Inc.
Putting Drywall Sanders to the Test: Power, Precision, and Dust Control
A pro painter evaluates a variety of drywall sanders and dust collection systems for quality of finish, user fatigue, and more.
