“Blonding”??? Wood trim
craigf | Posted in Construction Techniques on October 13, 2009 12:51pm
Replaced a door in a house built in the 60’s. All the casing and paneling in the rest of the house is blonde (if that’s the right terminology). The casing is actually metal with a faux finish.
I thought blonde oak casing would match it.
What is the process to make a blonde finish?
    McDesign | Oct 13, 2009 12:57am | #1
    < What is the process to make a blonde finish?  >
    Uhh - so much occurs to me here . . .
      Dam_inspector | Oct 13, 2009 02:14am | #3
      Tell her you'll buy her some new shoes?
    2. craigf | Oct 13, 2009 03:54pm | #9
      Yeah-there ought to be a good one in there somewhere.Gotta wonder about this place when a Prospero search turns up a bunch of blond jokes.
      1. craigf | Oct 13, 2009 04:02pm | #10
        My camera is broke or I'd post some pics. The finish I'm after is more of an opague white one. Mostly white, but you can still see some grain.I picked up some Ben Moore pickling stain, but it just put more of a whitish tinge to the grain and no color to the rest.I'll try a wash coat first with the stain on top and see what that does.
      2. DanH | Oct 14, 2009 01:54am | #11
        It was simply too easy and obvious of a target.
        As I stood before the gates I realized that I never want to be as certain about anything as were the people who built this place. --Rabbi Sheila Peltz, on her visit to Auschwitz
        1. craigf | Oct 14, 2009 02:19am | #12
          Simply had to be done :)
    3. Jercarp | Oct 14, 2009 04:17am | #13
      "Uhh - so much occurs to me here . . ."You're gonna burn.
      1. DanH | Oct 14, 2009 04:19am | #14
        Or at least get warts.
  2. YesMaam27577 | Oct 13, 2009 01:40am | #2
    If 'blonde' means whitewashed, then you need to go to a paint store and get some whitewash stain.
    Or, if 'blonde' simply means a clear wood finish that has little or no color -- use varnish. Or super-blonde shellac. Or brushing lacquer.
    I won't be laughing at the lies when I'm gone,
    And I can't question how or when or why when I'm gone;
    I can't live proud enough to die when I'm gone,
    So I guess I'll have to do it while I'm here. (Phil Ochs)
  3. alias | Oct 13, 2009 02:56am | #4
    hey craig this is a bit of say what ?? question . Respectfully , take some pictures and try to construct the question with the pic's . When your not sure of the nomenclature , and when trying to describe a blanket color as blond and actually metal with a faux finish. Your throwing a wide net there with not enough information.
    1. alias | Oct 13, 2009 03:00am | #5
      Does the casing a sort of smaller brick molding configuration?? what type of doors or in the opening? you might have to look in the direction of a glaze again pic's help
      Edited 10/12/2009 8:01 pm ET by alias
  4. renosteinke | Oct 13, 2009 03:16am | #6
    It sounds like the wood has a whitish tinge to it. This is sometimes called 'piclking.' Check the Minwax line at the store; I'm pretty sure they have a kit for this.
    1. alias | Oct 13, 2009 03:30am | #7
      thats a point... he probably should use a wash coat before the" pickling stain" , would even out the finish.
  5. DanH | Oct 13, 2009 03:37am | #8
    There are many wood colors/treatments that could be considered "blonde". Obviously, the simplest is a light-colored wood with a clear finish. After that there's wood bleach, bleaching with lye, and various opaque and semi-opaque finishes.
    Jeff_Clarke | Oct 14, 2009 07:30am | #15
    1. craigf | Oct 14, 2009 04:13pm | #16
      LOL. I like it!!!
Eichlers Get an Upgrade
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
