can insulation contractors remove blown in insulation as easily as they install–in an attic. Can they reverse the blower and suck all the stuff out? Getting ready to raise my ceilings to 9′ and want the easiest removal possible. thanks
I've seen it done. The system was a large blower mounted in a big panel truck, the application was for wet-spraying the insulation between exposed stud wall. While one person sprayed the cellulose, another shaved it off flush with the studs using this motorized brush gizmo and a third sucked up the excess off the floor with a hose that fed the insulation back into the blower.
great...........thank you
