Boiler and A/C on Same Thermostat?
SethFrankel | Posted in Energy, Heating & Insulation on September 19, 2007 03:24am
I’m installing a Buderus wall mount boiler as well as a Lennox air conditioning unit in a remodel. My mechanical contractor tells me that without going very expensive thermostatic controls I’m not able to use the same residential-grade thermostat to control both units.
Does this ring true? It seems odd that both units can’t be controlled by a single thermostat by just switching from heat to a/c.
Thanks.
Seth
    BillHartmann | Sep 19, 2007 03:50am | #1
    I know it can be done with the addition of a cheap relay.
    And it has been awhile since I installed one, but IIIRC all of the digital setback units have jumpers on the (R and Rc maybe) and you can separate the heating terminals from the AC terminals.
  2. grpphoto | Sep 19, 2007 05:25am | #2
    Just checked out their web site. It seems that their control units contain much of the functionality of a thermostat. They also make a room sensing unit. If I understand the publications correctly, the control unit has the circuitry and logic for handling things like different temperature settings for different times of day ("setback") and determines when to cut the system on. The "sensing unit" is mounted where you would normally mount a thermostat and simply relays the temperature to the control unit.
    Maybe you could jerry-rig something, but I'd bet your HVAC man is correct.
    George Patterson
Rescuing Old Hardware
Whether it’s already in your house or picked up at a flea market, vintage hardware almost always needs help.
