boiler install over wood flooring
mbmmd | Posted in Energy, Heating & Insulation on April 23, 2005 03:24am
Does anyone here have the code reference regarding the requirements for installing a hot water boiler over existing plywood subfloor?  Unable to locate boiler in crawlspace!  What height airspace is required, etc.  In advance, thanks
  1. DanH | Apr 23, 2005 06:09am | #1
    Well, first you should check the mfgr's specifications for clearances, etc. But unless the boiler is speced for installation on a wood floor, you're probably going to have to install some sort of tile or firebrick, or get a fireproof pad to go under the unit. In general, just a metal sheet won't do it.
  2. TJK1141 | Apr 23, 2005 08:55am | #2
    The boiler installation manual should list the minimum clearances to combustibles and the specs for intake air and venting. You will also need a drain for the pressure relief valve and for service. Consider a full pan (like a shower stall) -- you don't want 20 gallons of hot water on that plywood floor...
