Boilers and hot water
| Posted in Energy, Heating & Insulation on August 1, 2004 09:29am
We are going to be heating water with a boiler (propane or oil-fired, undecided) for hydronic RFH on the main 2200 sf floor of a two story house.
Give me some recommendations for heating water for showers, laundry, etc.  There are 2 full baths and one powder room, plus a kitchen with dishwasher, and laundry.
Local electric rates are ridiculously low, in the range of 4 cents.  There is a moratorium on the use of electric boilers for doing RFH in new construction.
  1. timkline | Aug 02, 2004 03:30am | #1
    Why the moratorium ?
    carpenter in transition
    1. gdavis62 | Aug 02, 2004 03:43am | #2
      Too much new construction using RFH and electric boilers is taxing the capacity of the municipal electric plant.
  2. EdJW | Aug 02, 2004 03:48am | #3
    Bob, you could go with an indirect water heater. Recovery time is great.  -Ed
  3. TRice | Aug 19, 2004 09:46pm | #4
    Indirect Fired DHW, run on a priority zone off of the boiler.
    BTW, with a 90% efficient appliance, $0.04/kwh is the equivalemt of $1.03/gallon of propane (avg-exp) or $1.05/therm for ng (very exp). In other words, moratorium or not, electric resistance is still (usually) the most expensive way to heat.
  4. csnow | Aug 20, 2004 10:54pm | #5
    Indirect tank is the way to go.  Also leverages your investment that much more if you should spring for higher efficiency boiler.
FHB Podcast Segment: Embodied Greenhouse Gas Emissions and the Building Codes
