hey folks , has any one used the bondera tile mat . i saw this product at the JLC trade show and it looked pretty nice , im thinking of using it on kitchen backsplash. any one out there use this product yet? would love your input thanks maguire
Understand lumens, ceiling brightness, beam spread, tilt, and color options to make a wise choice on a common fixture that can range from $75 to $750 or more.
Never used it but I know about it. I think it'd be fine for backsplashes. I personally think it's just another gimmick that'll come and go. Good for DIY'ers I spose'. For me when I want to make life easier on wall surfaces I just use mastic instead of mud. Mastic to me is as easy as it gets IMHO. If you need to make it easier than mastic..well...then I guess you're a DIY'er and thats fine. I don't know the cost difference either.
I have no idea how well this product works over time being it's new.
I certainly wouldn't trust it quite yet in wet areas.
Recently, I had a job tiling a backsplash with subway tiles. I used mastic. I had considered using Bondera tile mat, which probably would have worked just fine, but decided against it for 3 reasons: 1) I don't see it as a tried and true product yet, 2) because of obstructions such as outlets, I felt mastic would be easier and 3) the instructions actually required grouting within a limited period of time. That leads me to believe that this product relies on the grout to prevent movement. That may not be an issue, but I have to wonder if it's really as strong as bond as mastic or thinset.
I LOVE Bondera!
I had experience with mastic and I was a little nervous to try something new. I started with a small bathroom backsplash. I was done and ready to grout in a matter of minutes. Just be sure and take your time on the placement of you tile peices. It is possible to pull the peice off and tweak the set a bit, but it is very difficult to, because the bondera is so sticky. The Bondera may have to be cut away if you make a mistake. Just cut and reapply a small patch in that spot and move right on.
Where Bondera saves a lot of time is not having to wait for the mastic to dry. You just slap your tile up in a matter of minutes and then go ahead and grout. It's amazing and a whole lot less messy.
