Sq d type 3 up or down meter socket, weatherproof, came in a sealed box.
Do these not come w/ a bonding lug/screw or am I missing parts?
In this FHB Podcast Segment, the crew goes over some important details about different types of ventless dryers.
Greetings duke,
This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
Perhaps it will catch someone's attention that can help you with advice.
Cheers
Parolee # 53804
Duke,
Meter socket with main, or meter only? The neutral /ground bonding is usually made at the main switch (service disconnect).
Meter sockets often come with a small lug attached to the neutral bar which can be used for grounding. If yours doesn't have one, does it have threaded holes on the neutral buss for you to attach your own?
LEE
Edited 4/18/2007 1:06 pm ET by edlee
Edited 4/18/2007 1:10 pm ET by edlee
