Bonding Stainless Steel sink to tile
delpi | Posted in Construction Techniques on July 13, 2008 07:16am
Good afternoon –
I’m completing an outdoor kitchen (covered – no freezing) with a tile countertop. The sink I will install has clips that aren’t long enough to work with a layer of tile, a layer of tile backer, and a 3/4 sheet of MDF.
I can jury rig some clips but I’m wondering is just bonding the sink to the tile with silicone or a product like Loctite’s Power Grab would suffice and keep these old bones from crawling under the sink.
Any thoughts or suggestions or experience with same would be appreciated.
Thanks,
Dave
  1. ponytl | Jul 13, 2008 07:21pm | #1
    yes... any good sealant will hold it in place... i see undermount sinks set that way with no mechanical attachment all the time  and you can stand in em and won't break em loose... ur fine
    p
    shelternerd | Jul 13, 2008 08:43pm | #2
    Alternatively you can fold up steel strapping tape and get it to catch in the sink track with a long tail hanging down. Bring the tape over a wood block to the underside of the counter and then use a pan head screw to tighten the tape by flexing it between the block and the attachment point. I've done it this way several times with no problems.
    M
  3. Piffin | Jul 13, 2008 10:15pm | #3
    Just order the longer clips. Most sink makers have them as an option
  4. Pelipeth | Jul 14, 2008 02:52am | #4
    I'd stick with GE silicone. No pun intended, this keeps things REAL simple and neat.
    Edited 7/13/2008 7:54 pm ET by Pelipeth
  5. RedfordHenry | Jul 14, 2008 03:46am | #5
    Any good sealant will suffice.  Wish I could say the same for the MDF.
  6. MSA1 | Jul 14, 2008 03:49am | #6
    I've run into a similar situation in the past. I found a decent plumbing supply house (and I was in the sticks) that stocked longer clamps.
  7. jej | Jul 14, 2008 04:58am | #7
    the way i do it is bore a hole in the wood the size of the clamp then your clamps will work
  8. timkline | Jul 14, 2008 01:27pm | #8
    i hope you mean MDO not MDF
    carpenter in transition
  9. User avater
    SteveInCleveland | Jul 14, 2008 03:33pm | #9
    I've run into this situation a few times.  What I  figured out was that I could use my biscuit joiner to cut a slot in the substrate (in your case - the 3/4" MDF) where you want each clip.  Then I just slide the bottom of the clip into these grooves and tighten them up as you usually  would.
    "Preach the Gospel at all times; if necessary, use words."  - St. Francis of Assisi
