Bonfiglioli Insulation
nlbailey | Posted in Energy, Heating & Insulation on January 30, 2023 08:19am
I am looking for a wall assembly for an addition / remodel and keep coming back to the Bonfiglioli wall assembly as a good choice.
The only thing I don’t understand is the wall depth for insulation. With 2×6 wall framing, foam strips and 1×3 furing strips that gives you 7.25” of depth. In the article it references R-30 with fiberglass insulation but as far as I am aware there isn’t R-30 available in that depth.
I know mineral wool can fit that cavity but the article specifies using fiberglass as the reason it is a lower cost per sq. ft.
Am I missing something? Anyone have any insight into this?
  1. calvin | Jan 30, 2023 09:26am | #1
    Here’s some discussion on what you ask. Green Building Adviser is mentioned, so there might be further info there as well.
    https://www.energyvanguard.com/blog/compressed-fiberglass-insulation-really-so-bad/
    1. nlbailey | Jan 30, 2023 10:51am | #2
      Calvin, thank you for the link. I read through the discussion on that page and I have reviewed the charts for fiberglass insulation when compressed before. That's what I don't understand though. The Bonfiglioli article describes it as a R-30 wall with fiberglass batts but there isn't a way to get that much into a 7.25" depth.
      The closest options I've found is R-30 Cathedral ceiling batts that are 8.25" depth but when compressed gives you R-27. There is also R-38 Cathedral ceiling batts that are 10.25" depth but when compressed in the 7.25" cavity will only give you R-29. I guess that is close enough to call R-30 but then the cost doesn't make sense.
      I've looked through Green Building Advisor as well but haven't found any information on it either. I feel like there must be some detail that I've overlooked but can't figure it out.
      P.S. Looks like I'm just down the road from you!
      1. calvin | Jan 30, 2023 06:14pm | #3
        Maumee, Ohio
        Back in the woods above the flood plain.
        Luckily, most people are unaware we live back here.
        Guess a long lonely driveway (spooky) is enough.
        And where would you be?
        (Edit: I see now, Lima.)
        Back to bizness. Search here for Mooney Wall. A long ago member dreamt it up. And a good builder friend from Rhode Island has done it many times. Similar idea but with blown cells.
    SarahNolyer | Sep 20, 2023 11:40pm | #4
    You are right about the 2x6 wall assembly creating a 7.25" depth, which doesn't typically match R-30 fiberglass insulation. The article may prefer fiberglass due to its lower cost. Remember, insulation performance depends on more than just R-value; factors like installation and climate matter. If you are concerned about R-value, consult a roof repair local expert for tailored advice..
