I talked to neighbor yesterday and he was interested in replacing his old witndows with new energy efficient ones.
Is there a book that takes you through the steps? Thanks.
There have been several threads on here that discuss the pros and cons of replacing vs refurbishing windows. You may want to refer him to those discussions. Often refurbishing is a better choice, but not always.
There are a lot of good books on refurbishing windows, but I've not really been able to find anything decent on replacing windows.
I don't think he is interested in refurbishing. He's an engineer with two little kids so i think he wants to save some money and do it himself. He's completely restoring his fathers Mustang in his garage so he's pretty handy. I offered to help with his projects. I'm trying to be a good neighbor and help these young families if I can. It would be nice to have a book on the basics of replacing an old window with a new one. It's so common for people to want to do.
Sounds like a prime target for "conversion" to the "refurbish, don't replace" denomination :-)
Disclaimer: I prefer refurbishment over replacement in most cases.
The only book I have found is the Taunton Press Windows and Doors book. It had an article from FHB explaining the different types of replacement windows and brief directions on the process. I would like to find a step by step how-to, but have not yet found that book.
I have a couple of Andersen windows, about 23 years old, that could use new glass. It looks like it would be quite a job to replace.
I have been looking for info on that subject to avoid replacing an entire window. In one of my windows, for instance, only the center window in a panel of three has developed a leak between the panes, I think it would cost about $2k to replace this window, and could get the glass for about a hundred, if I could get the thing apart without destroying it.
Any ideas?
I had Anderson windows in my last house. They were crank out casements. When one would break you just replace the part that cranks out. In the basement there were about 8 of them with broken glass from the previous owner.
But there was one that was a fixed window between ones that cranked out that was broken. On the inside there were pieces of moulding that popped out with a little persuation. Behind the moulding were screws that held in the window. I took that to the window shop in town and had them fix it. The whole frame didn't have to come out. Just like a sub frame.
I'd explore by removing some of the moulding on the inside. I use flat bars or stiff putty knives so there is no damage to the moulding.
Edited 12/6/2007 9:52 am ET by popawheelie
Thanks for the info. I'll give it a try.
Unfortunately, I'm not really familiar with repairing Andersen windows - the windows I have refurbished have been the traditional wood double hung windows.
At those prices, I am assuming thes are pretty large windows?
I vaguely recall seeing an article (maybe in FHB?) on repairing windows such as yours. I think it is also covered in the window repair book - I'll have to dig a bit to find the exact title.
I would appreciate it if you have the tiltle of a good book on the subject. Yes, these are each about 2' X 6'. I figured I would have to replace all three as a unit, but it looks like luck is on my side.
OK, I found it:
Author
Meany, Terry.
Title
Working windows : a guide to the repair and restoration of wood windows / Terry Meany.
Publisher
Guilford, Conn. : Lyons Press, c2005.
Edition
Rev. and updated ed.
Description
xvii, 233 p. : ill. ; 24 cm.
Great!
Thanks again.
