In the attic today and looked up and was able to see a little daylight where the copper vent pipe exits the asphalt shingle roof. I don’t think that the rubber boot is tight enough around the pipe. Do I replace the boot or can I use a little roofing cement or caulk or is there some other way to seal the opening? Thanks.
This home features dramatic interior spaces enhanced by views of the surrounding trees and stream.
Roofing cement won't work. It's too stiff and as the pipe and roof expand and contract the seal will break. Same for caulk. It really should be replaced.
you can buy a replacement "donut" that you just slide over the pipe down against the old one and your done. they seem to be hard to find as i only know of one place to get them around here. i think oakley is the manf. larry
if a man speaks in the forest,and there's not a woman to hear him,is he still wrong?
"Oatey"
sounds right,i must have been thinking sunglass's. thanksif a man speaks in the forest,and there's not a woman to hear him,is he still wrong?
Thanks Larry. That Donut or "rain guard" by Oatey seems like the ticket. I will try and locate one.
Any of that plastic will be aproblem in 5-7 years. USE LEAD BOOTS.
I don't think they're listening to us.http://grantlogan.net/
"Because I really want to live in a country where the poor people are fat. "- Unidentified Indian Immigrant when asked why he wants to come to America
Go ahead Lexington, I'm listening...Where does one normally find a lead boot, other than the East River?'Man who say it cannot be done should not interrupt man doing it' ~ Chinese proverb
Roofing supply store, plumbing supply store, and my Lowes carries several of the most popular sizes (3",4"). They're in the plumbing department. I bought one this AM.http://grantlogan.net/
Thanks Grant. I'll check it out at the plumbing shop this week.Anything you'd add to Mongo's install notes above?'Man who say it cannot be done should not interrupt man doing it' ~ Chinese proverb
Nah. He banged the nail on the head. Except, don't put any nails in it where they'll show. One of my pet peeves.http://grantlogan.net/
They never have. Lets put a 5 year boot on a 30-year roof and complain when it leaks.
But the 5 year boot is $5 and the lead boot is $30.http://grantlogan.net/
When you can save that kind of money, who cares about peoples roofs?
Replace it with a lead boot and be done with it. Those neoprene gasket boots last about 5-7 years. We replace several hundred of them a year. They're my most frequent service call problem.
I assume they make a lead boot for metal roofing, but I've never seen one.
Got any sources??
I've fought a few leaks in the neoprene one's (especially on steep pitches) But haven't found a better mouse trap yet.
On the last problematic 3" vent, I made a tophat out of a lead flashing to cover the rubber penetration. Didn't look too great, but it was 40' up on the roof. So hard to see.
Ray
I used to order the lead boots through the local plumbing supply house.They have a little form I fill out, things like the existing vent pipe size, height of lead pipe I want, pitch of roof, size of base plate needed, and weight of lead desired. Someone off in the unknown fabricates it and it shows up a few days later.Slide it over the existing vent pipe like a sleeve, then roll the top of the lead over and down inside the existing vent pipe.
Nah, I don't think so. I seldom work with anything but copper and we make copper boots for copper roofs. The "counter flash" idea of yours is a good one. The failing point is the gasket against the pipe, so taking a lead boot and trimming it down so it covers the top of the pipe and extends down over the gasket might be just the ticket. http://grantlogan.net/
I just came from a condo property management company here in N.J. and they told me that they just contracted to have all 704 roof boots replaced with new boots. They said the're paying $19,000.00 for the new boots.
I like your advice re: lead boots. Problem is that roofing supply companies tell me that the lead boots that they carry are meant for flat roofs. My a/s roof has a pitch of 12-5.
Should I be able to carefully bend the lead boot so that it matches the slope of my roof or should I look further for a lead boot manufactured for my roof pitch?
Thanks for your good advice.
The only ones that I have seen are adjustable from flat to 12/12. They accordian on the high side to the necessary pitch.
http://www.bestmaterials.com/lead-roof-pipe-flashing-651.htmlhttp://grantlogan.net/
I refuse to accept that there are limitations to what we can accomplish. Pete (I am so in love with myself) Draganic
The simplest and least expensive fix is to buy the proper size metal/rubber roof flashing, uncrimp and remove the rubber boot, and slide it down over the vent pipe. This will not only create a counterflashing to seal the leak (and will conform to the pipe better because it is not being distorted by the angle of the base) but will also protect the primary roof boot from further degradation from UV.
Solar & Super-Insulated Healthy Homes
