I’d like to bore two insulated steel doors for dead bolts.
Is this feasible?
Whats the odds of “wood” being present in the area few inches about the bore for the hand set?
Scott
Most good steel doors will have some sort of reinforcement for this. Usually wood.
You can sort of check by tapping the door to hear if it is denser near the lockset area. It's not a perfect technique, but a start. Otherwise see if you can check with the manufacturer.
WIVELL,
No problem, go ahead and do it.
Davo
Thanks guys. Checked out a Lennox set of hole saws this morning - $27.
Sounds like I'll be good to go.
Scott
